[Qgis-user] Multiplicity in Model Input (Layers)
Alexandre Neto
senhor.neto at gmail.com
Thu Jul 15 00:46:59 PDT 2021
Hi Andrew,
You need to use the "multiple input" input type.
Best regards
Alexandre Neto
User support
www.qcooperative.net
A quinta, 15/07/2021, 08:33, Andrew Hughes <ahhughes at gmail.com> escreveu:
> Hi All,
> Could any provide some advice as I am new to this and need some guidance
> please.
> My model needs to consume data from MULTIPLE Esri rest layers. I can do
> this for on a 1:1 basis where I manually add 1 input vector layer per esri
> rest layer. But that's not great. This model is not easily reusable, as the
> number of layers always varies.
> Q1: The merge processor takes in a multi-layers on a single input - but I
> can't see how this is done in a model. Can anyone please explain?
> Q2: Is is possible for me to write a python processor that doesn't require
> any project layers as input, it can create the layers itself (in
> code/config) and feed them into the merge processor and output the single
> merged layer?
> Thanks in advance
> Andrew
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210715/74bdd17c/attachment.html>
