[Qgis-user] Group Statistics Tool
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Sun Jul 18 11:40:39 PDT 2021
This is like a cross tab or a pivot table in Excel. You need to place the polygon layer in the column field.
https://anitagraser.com/2013/02/02/group-stats-tutorial/
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 18 juill. 2021 à 12:47, krishna Ayyala <ayyalakrishna at gmail.com> a écrit :
> Nicolas,
> Thanks for your reply.They are not multi polygons. They are two separate polygons. That means A with area 60 is one polygon and A with area 30 is second polygon. If I select one polygon on the map, only one polygon gets highlighted. But, in group stats ,I have selected the first row which is A 60. I clicked "Features" and then "Show selected on map" both the polygons on the map are getting highlighted. As I mentioned before, only one polygon should get highlighted. If I create a unique id, that will not serve the purpose. I am trying to derive the polygon with maximum area from the list of polygons that are labeled as A.
> Regards.
>> On Sun, Jul 18, 2021 at 9:58 AM Nicolas Cadieux <njacadieux.gitlab at gmail.com> wrote:
>> Hi,
>> I do you have multipolygons in your input files? If not, perhaps the multipolygon is being created because both polygon have the same ID, A. Try creating a unique id field to see what is going on. A multipolygon or multipart object will contain multiple polygons but only one data line in the data table. You can split multipolygon with a «multiple to single »tool found in the vector menu.
>> Nicolas Cadieux
>>>> Le 17 juill. 2021 à 20:56, krishna Ayyala <ayyalakrishna at gmail.com> a écrit :
>>> Hello,
>>> I have a polygon shape file with an attribute table as shown below.
>>> <image.png>
>>> I am using the Group stats tool to derive only those rows that have max area for each polygon. After clicking calculate, I got the results below. In the below window. I have selected the first row which A 60. I clicked "Features" and then "Show selected on map" . Technically, it is supposed to highlight only one polygon which is A with an area 60 on the map. But is highlighting both the polygons i.e..A with an area 60 and also A with an area 30. Is there a way to select only the polygon A with an area 60?
>>> <image.png>
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210718/ee61cbed/attachment.html>
