[Qgis-user] Group Statistics Tool
krishna Ayyala ayyalakrishna at gmail.com
Sun Jul 18 12:15:46 PDT 2021
When I enter the Polygon in the column field and calculate, I am getting
like this. When I select row 2 and Click Features --- Show Selected on map,
all the four polygons are getting highlighted.
[image: image.png]
On Sun, Jul 18, 2021 at 12:40 PM Nicolas Cadieux <
njacadieux.gitlab at gmail.com> wrote:
> Hi,
> This is like a cross tab or a pivot table in Excel. You need to place the
> polygon layer in the column field.
> https://anitagraser.com/2013/02/02/group-stats-tutorial/
> Nicolas Cadieux
> https://gitlab.com/njacadieux
> Le 18 juill. 2021 à 12:47, krishna Ayyala <ayyalakrishna at gmail.com> a
> écrit :
> Nicolas,
> Thanks for your reply.They are not multi polygons. They are two
> separate polygons. That means A with area 60 is one polygon and A with area
> 30 is second polygon. If I select one polygon on the map, only one polygon
> gets highlighted. But, in group stats ,I have selected the first row which
> is A 60. I clicked "Features" and then "Show selected on map" both the
> polygons on the map are getting highlighted. As I mentioned before, only
> one polygon should get highlighted. If I create a unique id, that will not
> serve the purpose. I am trying to derive the polygon with maximum area
> from the list of polygons that are labeled as A.
> Regards.
> On Sun, Jul 18, 2021 at 9:58 AM Nicolas Cadieux <
>> Hi,
>> I do you have multipolygons in your input files?  If not, perhaps the
>> multipolygon is being created because both polygon have the same ID, A.
>> Try creating a unique id field to see what is going on.  A multipolygon or
>> multipart object will contain multiple polygons but only one data line in
>> the data table. You can split multipolygon with a «multiple to single »tool
>> found in the vector menu.
>> Nicolas Cadieux
>> Le 17 juill. 2021 à 20:56, krishna Ayyala <ayyalakrishna at gmail.com> a
>> écrit :
>> Hello,
>> I have a polygon shape file with an attribute table as shown below.
>> <image.png>
>> I am using the Group stats tool to derive only those rows that have max
>> area for each polygon. After clicking calculate, I got the results below.
>> In the below window. I have selected the first row which A 60. I clicked
>> "Features" and then "Show selected on map" . Technically, it is supposed to
>> highlight only one polygon which is A with an area 60 on the map. But is
>> highlighting both the polygons i.e..A with an area 60 and also A with an
>> area 30. Is there a way to select only the polygon A with an area 60?
>> <image.png>
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210718/7b7f9d85/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210718/7b7f9d85/attachment-0001.png>
