[Qgis-user] Find / checkout different branches Github
    Raymond Nijssen
    r.nijssen at terglobo.nl
    Tue Jul 27 00:41:41 PDT 2021
Hi Piet,
On the command line:
 > git branch
Will give you all the branches in the repository, where you will find
release-3_20
 > git checkout release-3_20
Will set your code to that branch
 > git pull
Will fetch and update the latest code (including backported code for 3.20.1
Now you can build your 3.20, which will be 3.20.1
To all, correct me if I'm wrong here, please! :)
Kind regards,
Raymond
On 27-07-2021 08:51, APM wrote:
> Dear List,
> my questions are more related to the git system, but I hope you'll give
> me some information.
> I like to compile QGIS on my own following
> https://github.com/qgis/QGIS/blob/master/INSTALL.md#36-check-out-the-qgis-source-code
> But I like to compile Qgis 3.20 and not the developement version.
> My questions:
> How to find the avaible versions ("branches"?) by using a 'git'-command ?
> How to checkout a special version?
> Further, what is the difference between "backport-43897-to-release-3_20"
> and "backport-44030-to-release-3_20"?
> Futher, I red that there's a version 3.20.1, but I can't find it?
> Is this the 'master' branch?
> Thank you very much!
> Kind regards
> Piet
> Qgis-user mailing list
