[Qgis-user] Find / checkout different branches Github
Piet
apschwimmer at apmland.de
Tue Jul 27 02:00:14 PDT 2021
Hi Raymond,
thank you for your hints.
Compiling 3_20 is in progress now :)
But 'git branch' shows
master
* release-3_20
but not all branches like 3.16 etc.
It seems that 'git branch' shows the local branch only?
Kind regards
Piet
Am 27.07.21 um 09:41 schrieb Raymond Nijssen:
> Hi Piet,
> On the command line:
> > git branch
> Will give you all the branches in the repository, where you will find
> release-3_20
> > git checkout release-3_20
> Will set your code to that branch
> > git pull
> Will fetch and update the latest code (including backported code for
> 3.20.1
> Now you can build your 3.20, which will be 3.20.1
> To all, correct me if I'm wrong here, please! :)
> Kind regards,
> Raymond
> On 27-07-2021 08:51, APM wrote:
>> Dear List,
>> my questions are more related to the git system, but I hope you'll
>> give me some information.
>> I like to compile QGIS on my own following
>> https://github.com/qgis/QGIS/blob/master/INSTALL.md#36-check-out-the-qgis-source-code
>> But I like to compile Qgis 3.20 and not the developement version.
>> My questions:
>> How to find the avaible versions ("branches"?) by using a
>> 'git'-command ?
>> How to checkout a special version?
>> Further, what is the difference between "backport-43897-to-release-3_20"
>> and "backport-44030-to-release-3_20"?
>> Futher, I red that there's a version 3.20.1, but I can't find it?
>> Is this the 'master' branch?
>> Thank you very much!
>> Kind regards
>> Piet
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
