[Qgis-user] Find / checkout different branches Github
    Ismail Sunni
    imajimatika at gmail.com
    Tue Jul 27 02:12:38 PDT 2021
Hi Piet,
To list all branches, including the remote one, you can use *git branch -a.*
Best regards
On Tue, Jul 27, 2021 at 11:05 AM Piet <apschwimmer at apmland.de> wrote:
> Hi Raymond,
> thank you for your hints.
> Compiling 3_20 is in progress now :)
> But 'git branch'  shows
>    master
> * release-3_20
> but not all branches like 3.16 etc.
> It seems that 'git branch' shows the local branch only?
> Kind regards
> Piet
> Am 27.07.21 um 09:41 schrieb Raymond Nijssen:
> > Hi Piet,
> > On the command line:
> > > git branch
> > Will give you all the branches in the repository, where you will find
> > release-3_20
> > > git checkout release-3_20
> > Will set your code to that branch
> > > git pull
> > Will fetch and update the latest code (including backported code for
> > 3.20.1
> > Now you can build your 3.20, which will be 3.20.1
> > To all, correct me if I'm wrong here, please! :)
> > Kind regards,
> > Raymond
> > On 27-07-2021 08:51, APM wrote:
> >> Dear List,
> >> my questions are more related to the git system, but I hope you'll
> >> give me some information.
> >> I like to compile QGIS on my own following
> https://github.com/qgis/QGIS/blob/master/INSTALL.md#36-check-out-the-qgis-source-code
> >> But I like to compile Qgis 3.20 and not the developement version.
> >> My questions:
> >> How to find the avaible versions ("branches"?) by using a
> >> 'git'-command ?
> >> How to checkout a special version?
> >> Further, what is the difference between "backport-43897-to-release-3_20"
> >> and "backport-44030-to-release-3_20"?
> >> Futher, I red that there's a version 3.20.1, but I can't find it?
> >> Is this the 'master' branch?
> >> Thank you very much!
> >> Kind regards
> >> Piet
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Ismail Sunni
Software Engineer
ismailsunni.id
ismailsunni.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210727/d2a49963/attachment.html>
