[Qgis-user] Find / checkout different branches Github
    Piet
    apschwimmer at apmland.de
    Tue Jul 27 02:34:55 PDT 2021
Hello Ismail,
that's it, thank you!
Kind regards
Piet
Am 27.07.21 um 11:12 schrieb Ismail Sunni:
> Hi Piet,
> To list all branches, including the remote one, you can use /git
> branch -a./
> Best regards
> On Tue, Jul 27, 2021 at 11:05 AM Piet <apschwimmer at apmland.de
> <mailto:apschwimmer at apmland.de>> wrote:
>     Hi Raymond,
>     thank you for your hints.
>     Compiling 3_20 is in progress now :)
>     But 'git branch'  shows
>        master
>     * release-3_20
>     but not all branches like 3.16 etc.
>     It seems that 'git branch' shows the local branch only?
>     Kind regards
>     Piet
>     Am 27.07.21 um 09:41 schrieb Raymond Nijssen:
>     > Hi Piet,
>     > On the command line:
>     > > git branch
>     > Will give you all the branches in the repository, where you will
>     find
>     > release-3_20
>     > > git checkout release-3_20
>     > Will set your code to that branch
>     > > git pull
>     > Will fetch and update the latest code (including backported code
>     for
>     > 3.20.1
>     > Now you can build your 3.20, which will be 3.20.1
>     > To all, correct me if I'm wrong here, please! :)
>     > Kind regards,
>     > Raymond
>     > On 27-07-2021 08:51, APM wrote:
>     >> Dear List,
>     >> my questions are more related to the git system, but I hope you'll
>     >> give me some information.
>     >> I like to compile QGIS on my own following
>     https://github.com/qgis/QGIS/blob/master/INSTALL.md#36-check-out-the-qgis-source-code
>     <https://github.com/qgis/QGIS/blob/master/INSTALL.md#36-check-out-the-qgis-source-code>
>     >> But I like to compile Qgis 3.20 and not the developement version.
>     >> My questions:
>     >> How to find the avaible versions ("branches"?) by using a
>     >> 'git'-command ?
>     >> How to checkout a special version?
>     >> Further, what is the difference between
>     "backport-43897-to-release-3_20"
>     >> and "backport-44030-to-release-3_20"?
>     >> Futher, I red that there's a version 3.20.1, but I can't find it?
>     >> Is this the 'master' branch?
>     >> Thank you very much!
>     >> Kind regards
>     >> Piet
>     >> _______________________________________________
>     >> Qgis-user mailing list
>     >> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>     <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>     >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Ismail Sunni
> Software Engineer
> ismailsunni.id <http://ismailsunni.id>
> ismailsunni.wordpress.com <http://ismailsunni.wordpress.com>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210727/ccd62882/attachment.html>
