[Qgis-user] Fiber network Cables
    krishna Ayyala
    ayyalakrishna at gmail.com
    Wed Jul 28 12:32:02 PDT 2021
Nicolas,
Thanks for the reply. For the area below, I am attaching the shapefile
containing buildings and its centroids. When you get a chance, can you
please guide me on how to accomplish this task of shortest paths between
houses and servers?
[image: image.png]
On Wed, Jul 28, 2021 at 12:54 PM Nicolas Cadieux <
njacadieux.gitlab at gmail.com> wrote:
> Hi,
> The previous person that had this problem used the QGIS network analysis
> tool. It was easy because they followed a previously drawn network.  All
> they had to figure out was the shortest paths between houses and servers.
> If you follow that lead, I am developing a network checking model to help
> find problems.
> Nicolas Cadieux
> https://gitlab.com/njacadieux
> Le 28 juill. 2021 à 14:23, krishna Ayyala <ayyalakrishna at gmail.com> a
> écrit :
> Nicolas,
> I am not asking for the compatibility of the files nor am I asking on how
> to change the symbology. Previously when I used to have access to the fiber
> design software, after defining the area, the fiber design software has
> generated the fiber network. As I mentioned before I no longer have a
> subscription for this software. Is it possible to generate a similar design
> network using QGIS plugins/tools? In my previous email I mentioned about
> the font colors just to distinguish between the distribution cable and the
> drop cable. I was wondering if QGIS can produce a similar design?
> Regards.
> On Wed, Jul 28, 2021 at 11:40 AM Nicolas Cadieux <
>> Hi,
>> If the files created by the software are compatible with QGIS, simply
>> open the files, right click on the layer and go to layer properties, and
>> change the style.  What is the format for your layers?
>> https://docs.qgis.org/3.16/en/docs/user_manual/working_with_vector/vector_properties.html?highlight=style#symbology-properties
>> Nicolas Cadieux
>> Le 28 juill. 2021 à 11:37, krishna Ayyala <ayyalakrishna at gmail.com> a
>> écrit :
>> Hello,
>> Using the plugins/tools within QGIS, Is it possible to get the network as
>> shown below? I was able to get the following results using fiber design
>> software. I no longer have the subscription for that software. Hence, can
>> anyone help me accomplish this using the tools within QGIS? Blue font cable
>> is the distribution cable and the red font cable is the drop cable.
>> <image.png>
>> Regards.
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210728/9504419b/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210728/9504419b/attachment-0001.png>
Type: application/x-zip-compressed
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210728/9504419b/attachment-0001.bin>
