[Qgis-user] Fiber network Cables
Nicolas Cadieux njacadieux.gitlab at gmail.com
Wed Jul 28 11:54:05 PDT 2021
The previous person that had this problem used the QGIS network analysis tool. It was easy because they followed a previously drawn network.  All they had to figure out was the shortest paths between houses and servers.  If you follow that lead, I am developing a network checking model to help find problems.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 28 juill. 2021 à 14:23, krishna Ayyala <ayyalakrishna at gmail.com> a écrit :
> Nicolas,
> I am not asking for the compatibility of the files nor am I asking on how to change the symbology. Previously when I used to have access to the fiber design software, after defining the area, the fiber design software has generated the fiber network. As I mentioned before I no longer have a subscription for this software. Is it possible to generate a similar design network using QGIS plugins/tools? In my previous email I mentioned about the font colors just to distinguish between the distribution cable and the drop cable. I was wondering if QGIS can produce a similar design?
> Regards.
>> On Wed, Jul 28, 2021 at 11:40 AM Nicolas Cadieux <njacadieux.gitlab at gmail.com> wrote:
>> Hi,
>> If the files created by the software are compatible with QGIS, simply open the files, right click on the layer and go to layer properties, and change the style.  What is the format for your layers?
>> https://docs.qgis.org/3.16/en/docs/user_manual/working_with_vector/vector_properties.html?highlight=style#symbology-properties
>> Nicolas Cadieux
>>>> Le 28 juill. 2021 à 11:37, krishna Ayyala <ayyalakrishna at gmail.com> a écrit :
>>> Hello,
>>> Using the plugins/tools within QGIS, Is it possible to get the network as shown below? I was able to get the following results using fiber design software. I no longer have the subscription for that software. Hence, can anyone help me accomplish this using the tools within QGIS? Blue font cable is the distribution cable and the red font cable is the drop cable.
>>> <image.png>
>>> Regards.
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210728/b7242beb/attachment.html>
