[Qgis-user] Identify Results customization?
Michael Gieding
michael.gieding at live.de
Sat May 22 11:09:04 PDT 2021
Hello Kerrie,
maybe one of the experienced users here has got another idea or solution.
My temporary workaround would be, if your data is from PostgreSQL, Geopackage, Spatialite, etc.:
With the DB-Manager > SQL you can load the result of a select as layer to QGIS.
In the select statement you can define the fields which your users just need to see. Don't forget
the columns with the primary key and geom.
Hope it helps in the meantime.
Regards,
Michael Gieding
________________________________________
Von: Qgis-user <qgis-user-bounces at lists.osgeo.org> im Auftrag von Kerrie Bushway <kbushway at gmail.com>
Gesendet: Samstag, 22. Mai 2021 14:07
An: qgis-user at lists.osgeo.org
Betreff: [Qgis-user] Identify Results customization?
Hi -
I have a few layers in a QGIS project where I have hidden some unnecessary fields from the attribute table, however they still show up in the Identify Results window when using the Identify Tool. Is there a way to customize the fields seen in the Identify Results window?
Or is there another solution I can use so that my intended users (very beginner level) are only seeing the information they need to see in a stationary window? (Map Tips doesn't sound like what I need).
Thanks!
Kerrie Bushway
