[Qgis-user] Identify Results customization?
Kerrie Bushway kbushway at gmail.com
Wed May 26 04:04:07 PDT 2021
Thanks, this worked! Exploring the widgets capabilities more is on my to-do
list.
Kerrie
On Sat, May 22, 2021 at 9:03 AM Randal Hale <rjhale at northrivergeographic.com>
wrote:
> On the attribute window you can organize data and turn off fields - but
> they still appear using the identify window. Try this:
>    - Right click on your layer
>    - Go to properties
>    - Go to Forms
>    - Set the widget type for the field you want to hide to "hidden" and
>    it won't show up with identify results.....but it does still show up in the
>    attribute window........Heh. (I wasn't expecting that but I've learned
>    something).
> So I'm guessing it a combination of hiding the field using organize
> columns button and Setting with widget type to "hidden".
> On 5/22/21 8:07 AM, Kerrie Bushway wrote:
> Hi -
> I have a few layers in a QGIS project where I have hidden some unnecessary
> fields from the attribute table, however they still show up in the Identify
> Results window when using the Identify Tool. Is there a way to customize
> the fields seen in the Identify Results window?
> Or is there another solution I can use so that my intended users (very
> beginner level) are only seeing the information they need to see in a
> stationary window? (Map Tips doesn't sound like what I need).
> Thanks!
> Kerrie Bushway
> Qgis-user mailing listQgis-user at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210526/13924fd4/attachment.html>
