[Qgis-user] importing dwg/dxf
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Sun Nov 21 10:52:47 PST 2021
On 21.11.21 15:35, Nicolas Cadieux wrote:
> Hi,
> .dwg or dxf have no CRS. They can be in inches, feet, mm, cm, m...
> Usually meter in a local CRS like a local WGS84 UTM ZONE is used. You
> can usually find this in the metadata if available.
> Nicolas
I have no deep technical insight into dwg or dxf, but I am pretty sure
that those CAD-"products" are able to be produced with valid
coordinates, fitting to a common CRS. Most people using CAD-systems
simply seem to be either too stupid for that, or just do not care.
One of the reasons, CAD-"data" is produced with a local reference system
instead with a normal CRS is, according to an CAD-operator I once asked
about this, that some CAD-systems just slow down to in-operability when
using real-world coordinates because of the huge numbers, compared to
the small coordinates in their own system.
So, I would not even try to fix this, but instead ask those guys to stop
scratching their balls and better send you proper real-world data and
tell you which CRS they are in . The handling of this "data" is
punishment enough afterwords.
Hope my dislike for this "technology" was not too obvious ;)
Cheers,
Bernd
> On 2021-11-21 9:07 a.m., Greg Troxel wrote:
>> Boaz Bar Ilan<boazprosie at gmail.com> writes:
>>> i always have problem importing dwg or dxf . the layers dont fit the
>>> coardinations and even when i set the layers crs it doesnt work.
>> I am far from an expert, but recently tried to deal with a dwg.
>> My impression is that they are almost always in local coordinates, and
>> the path to success is something like using GeoScience plugin to define
>> a local CRS based on control points where you know global coordinates
>> and local, and then to use that CRS for the data.
>> I recently imported some "PNEZD" data (csv with point it, northing,
>> easting, vertical, and description, all in an unspecified local grid,
>> from a total station data collector) and used geoscience to align it
>> wtih RTK obsservations of a few points, and things fit quite well.
>> How are you getting dwg? Are you using the proprietary dwg library with
>> gdal, or is there some open source path?
>> Qgis-user mailing list
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211121/34e35a84/attachment.html>
