[Qgis-user] importing dwg/dxf
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Sun Nov 21 10:59:24 PST 2021
Only AutoCAD Map3D was a certain comprehension of what a CRS is. To my knowledge all other Autodesk Pilotdo not used any CRS. It is my honest opinion that AutoCAD Map is the worst attempt to make a GIS.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 21 nov. 2021 à 13:52, Bernd Vogelgesang <bernd.vogelgesang at gmx.de> a écrit :
> On 21.11.21 15:35, Nicolas Cadieux wrote:
>> Hi,
>> .dwg or dxf have no CRS. They can be in inches, feet, mm, cm, m... Usually meter in a local CRS like a local WGS84 UTM ZONE is used. You can usually find this in the metadata if available.
>> Nicolas
> I have no deep technical insight into dwg or dxf, but I am pretty sure that those CAD-"products" are able to be produced with valid coordinates, fitting to a common CRS. Most people using CAD-systems simply seem to be either too stupid for that, or just do not care.
> One of the reasons, CAD-"data" is produced with a local reference system instead with a normal CRS is, according to an CAD-operator I once asked about this, that some CAD-systems just slow down to in-operability when using real-world coordinates because of the huge numbers, compared to the small coordinates in their own system.
> So, I would not even try to fix this, but instead ask those guys to stop scratching their balls and better send you proper real-world data and tell you which CRS they are in . The handling of this "data" is punishment enough afterwords.
> Hope my dislike for this "technology" was not too obvious ;)
> Cheers,
> Bernd
>>> On 2021-11-21 9:07 a.m., Greg Troxel wrote:
>>> Boaz Bar Ilan<boazprosie at gmail.com> writes:
>>>> i always have problem importing dwg or dxf . the layers dont fit the
>>>> coardinations and even when i set the layers crs it doesnt work.
>>> I am far from an expert, but recently tried to deal with a dwg.
>>> My impression is that they are almost always in local coordinates, and
>>> the path to success is something like using GeoScience plugin to define
>>> a local CRS based on control points where you know global coordinates
>>> and local, and then to use that CRS for the data.
>>> I recently imported some "PNEZD" data (csv with point it, northing,
>>> easting, vertical, and description, all in an unspecified local grid,
>>> from a total station data collector) and used geoscience to align it
>>> wtih RTK obsservations of a few points, and things fit quite well.
>>> How are you getting dwg? Are you using the proprietary dwg library with
>>> gdal, or is there some open source path?
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211121/df683f1c/attachment-0001.html>
