[Qgis-user] File always reloads layers
Dario C
dario955i at gmail.com
Tue Oct 5 00:51:25 PDT 2021
Thank you for your quick reply. I'm going to do F12 staff and check.
I'm using 3.16.11 and same problem in the computer of a colleague, same
version without any plugin (new installation).
Thanks.
Il giorno mar 5 ott 2021 alle ore 09:36 Charles Dixon-Paver <
charles at kartoza.com> ha scritto:
> If you press the F12 key it will bring up the developer/ debug tools.
> Under the profiler tab, select the "Project Load" category and the Reading
> map layers section will give you the time it takes for QGIS to load each
> layer.
> For the layer rendering issue in the ToC it's hard to say what the issue
> is without more info or sample data. Maybe you could supply the layer
> definition, or copy it to a new project and see if it resolves the issue.
> The first step to troubleshooting is to start a new user profile. It may
> be a network drive, database connection, or even a faulty plugin causing
> your issues. In terms of recovery, .qgs files will store a .qgs~
> backup copy when saving, but over and above that users are largely expected
> to manage their version control themselves (the process will depend on the
> project storage format and location, as you can store projects in databases
> etc). But QGIS also has a host of features for copying and exporting
> layers/ styles/ layouts, and a lot of configuration options between
> projects in case you want to start over. QGS projects themselves are just
> XML as well, so it's possible to edit it with a text editor.
> Regards
> On Tue, 5 Oct 2021 at 09:19, Dario C <dario955i at gmail.com> wrote:
>> Hi, I'm working on a simple file with several layers. After months of
>> working, yesterday something went wrong: each time I click on a layer (just
>> click) or I do some simple action, Qgis goes in "not responds" .
>> Moreover, I have a categorized layer that it is well displayed in the
>> properties panel, but in the layer panel it looks as a simple symbol layer
>> (without flydown menu icon).
>> Is there any way to check what layer is corrupted or needs long time to
>> reload?
>> Or a general recovery method (like autocad)
>> Thanks
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211005/43ba7a5b/attachment-0001.html>
