[Qgis-user] File always reloads layers
Dario C
dario955i at gmail.com
Tue Oct 5 07:00:05 PDT 2021
I'm trying to make a new file. Probably there is a server problem and I
have to skip all the layer working with capabilities linked to this server.
very useful to know about this plugin for fixing shape file.
thank you for your support.
Il giorno mar 5 ott 2021 alle ore 14:09 Nicolas Cadieux <
njacadieux.gitlab at gmail.com> ha scritto:
> Hi,
> I see Charles gave you a good rundown of what to do. I would now create a
> new project and try to figure out if the problem is in the project files or
> the data files. It could probably help if you indicated what type of files
> you are using. Make sure you don’t have a file that relies on a plugin to
> open… (this happened to me in the past for some web formats). If so,
> reinstall that plugin. If you have .shp files, I would check out a tool
> called something like « fix shape file ». (Never used it.) I saw the tool
> for the first time this week in the processing toolbox when I was looking
> to fix geometries. Look for « fix » in processing.
> Nicolas Cadieux
> https://gitlab.com/njacadieux
> Le 5 oct. 2021 à 03:52, Dario C <dario955i at gmail.com> a écrit :
> Thank you for your quick reply. I'm going to do F12 staff and check.
> I'm using 3.16.11 and same problem in the computer of a colleague, same
> version without any plugin (new installation).
> Thanks.
> Il giorno mar 5 ott 2021 alle ore 09:36 Charles Dixon-Paver <
> charles at kartoza.com> ha scritto:
>> If you press the F12 key it will bring up the developer/ debug tools.
>> Under the profiler tab, select the "Project Load" category and the Reading
>> map layers section will give you the time it takes for QGIS to load each
>> layer.
>> For the layer rendering issue in the ToC it's hard to say what the issue
>> is without more info or sample data. Maybe you could supply the layer
>> definition, or copy it to a new project and see if it resolves the issue.
>> The first step to troubleshooting is to start a new user profile. It may
>> be a network drive, database connection, or even a faulty plugin causing
>> your issues. In terms of recovery, .qgs files will store a .qgs~
>> backup copy when saving, but over and above that users are largely expected
>> to manage their version control themselves (the process will depend on the
>> project storage format and location, as you can store projects in databases
>> etc). But QGIS also has a host of features for copying and exporting
>> layers/ styles/ layouts, and a lot of configuration options between
>> projects in case you want to start over. QGS projects themselves are just
>> XML as well, so it's possible to edit it with a text editor.
>> Regards
>> On Tue, 5 Oct 2021 at 09:19, Dario C <dario955i at gmail.com> wrote:
>>> Hi, I'm working on a simple file with several layers. After months of
>>> working, yesterday something went wrong: each time I click on a layer (just
>>> click) or I do some simple action, Qgis goes in "not responds" .
>>> Moreover, I have a categorized layer that it is well displayed in the
>>> properties panel, but in the layer panel it looks as a simple symbol layer
>>> (without flydown menu icon).
>>> Is there any way to check what layer is corrupted or needs long time to
>>> reload?
>>> Or a general recovery method (like autocad)
>>> Thanks
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211005/8af9547f/attachment.html>
