[Qgis-user] File always reloads layers
Dario C
dario955i at gmail.com
Tue Oct 5 09:40:01 PDT 2021
Solved. It was my mistake.
I have pressed the button "filter layer on map" unintentionally and it
works reloading layer continuesly...
Il Mar 5 Ott 2021, 16:00 Dario C <dario955i at gmail.com> ha scritto:
> I'm trying to make a new file. Probably there is a server problem and I
> have to skip all the layer working with capabilities linked to this server.
> very useful to know about this plugin for fixing shape file.
> thank you for your support.
> Il giorno mar 5 ott 2021 alle ore 14:09 Nicolas Cadieux <
> njacadieux.gitlab at gmail.com> ha scritto:
>> Hi,
>> I see Charles gave you a good rundown of what to do. I would now create
>> a new project and try to figure out if the problem is in the project files
>> or the data files. It could probably help if you indicated what type of
>> files you are using. Make sure you don’t have a file that relies on a
>> plugin to open… (this happened to me in the past for some web formats). If
>> so, reinstall that plugin. If you have .shp files, I would check out a
>> tool called something like « fix shape file ». (Never used it.) I saw the
>> tool for the first time this week in the processing toolbox when I was
>> looking to fix geometries. Look for « fix » in processing.
>> Nicolas Cadieux
>> https://gitlab.com/njacadieux
>> Le 5 oct. 2021 à 03:52, Dario C <dario955i at gmail.com> a écrit :
>> Thank you for your quick reply. I'm going to do F12 staff and check.
>> I'm using 3.16.11 and same problem in the computer of a colleague, same
>> version without any plugin (new installation).
>> Thanks.
>> Il giorno mar 5 ott 2021 alle ore 09:36 Charles Dixon-Paver <
>> charles at kartoza.com> ha scritto:
>>> If you press the F12 key it will bring up the developer/ debug tools.
>>> Under the profiler tab, select the "Project Load" category and the Reading
>>> map layers section will give you the time it takes for QGIS to load each
>>> layer.
>>> For the layer rendering issue in the ToC it's hard to say what the issue
>>> is without more info or sample data. Maybe you could supply the layer
>>> definition, or copy it to a new project and see if it resolves the issue.
>>> The first step to troubleshooting is to start a new user profile. It may
>>> be a network drive, database connection, or even a faulty plugin causing
>>> your issues. In terms of recovery, .qgs files will store a .qgs~
>>> backup copy when saving, but over and above that users are largely expected
>>> to manage their version control themselves (the process will depend on the
>>> project storage format and location, as you can store projects in databases
>>> etc). But QGIS also has a host of features for copying and exporting
>>> layers/ styles/ layouts, and a lot of configuration options between
>>> projects in case you want to start over. QGS projects themselves are just
>>> XML as well, so it's possible to edit it with a text editor.
>>> Regards
>>> On Tue, 5 Oct 2021 at 09:19, Dario C <dario955i at gmail.com> wrote:
>>>> Hi, I'm working on a simple file with several layers. After months of
>>>> working, yesterday something went wrong: each time I click on a layer (just
>>>> click) or I do some simple action, Qgis goes in "not responds" .
>>>> Moreover, I have a categorized layer that it is well displayed in the
>>>> properties panel, but in the layer panel it looks as a simple symbol layer
>>>> (without flydown menu icon).
>>>> Is there any way to check what layer is corrupted or needs long time to
>>>> reload?
>>>> Or a general recovery method (like autocad)
>>>> Thanks
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211005/662af582/attachment.html>
