[Qgis-user] QGIS server in professional use?
DelazJ delazj at gmail.com
Mon Oct 18 05:40:29 PDT 2021
Hi Mats, all
Just to let you know that some of the unclear/confusing statements in the
docs you pointed out in an earlier message have been addressed. The updated
version is available at
https://github.com/qgis/QGIS-Documentation/blob/master/docs/server_manual/getting_started.rst
and will be pushed to the docs website later tonight (UTC).
Hope that helps you get through or at least makes things less confusing.
And please open issues in the repo if there still are.
Regards,
Harrissou
Le lun. 18 oct. 2021 à 11:00, Mats Elfström <mats.elfstrom at giskraft.se> a
écrit :
> Nyall, and QGIS fellow users and friends!
> No one is born with knowledge, but everyone can learn.
> Which is what I am trying hard here.
> I humbly asked for user collaboration, and took great care in explaining
> what I have done, and what I am aiming at.
> (see also the thread "*Configuring QGIS server on Ubuntu 20.4*")
> I have not given up yet, but I will drop this thread.
> As you imply, it has taken off in the wrong direction.
> Best regards, Mats.E
> Den mån 18 okt. 2021 kl 09:44 skrev Nyall Dawson <nyall.dawson at gmail.com>:
>> On Mon, 18 Oct 2021 at 17:23, Mats Elfström <mats.elfstrom at giskraft.se>
>> wrote:
>> > I am not too happy if I have to start over on a new machine.
>> With all due respect, what do you expect as the outcome of this
>> discussion?  You're complaining about software you obtained for free!
>> If you're looking for commercial SUPPORT for QGIS then you need to
>> contract a QGIS support provider (see
>> https://qgis.org/en/site/forusers/commercial_support.html). If you're
>> not experienced enough to setup the server yourself, I strongly
>> caution you NOT to expose it to the internet and instead pay someone
>> with the experience to do this for you, and ensure it's done
>> correctly.
>> If it's a volunteer task and you don't want to pay for support, then
>> you NEED to moderate your language and avoid the inflammatory wording.
>> That's never an effective way to get a good response from the
>> volunteer side of the community.
>> Nyall
>> > Regards, Mats.E
>> > Den mån 18 okt. 2021 kl 04:31 skrev Richard Greenwood <
>> richard.greenwood at gmail.com>:
>> >> Posting again without screenshot, which apparently caused my previous
>> email to await moderator approval.
>> >> Mats,
>> >> I fired up a new Ubuntu 20.04 instance on AWS and did the following 5
>> steps which got me an XML capabilities document.
>> >> # standard practice when starting a new instance
>> >> sudo apt update && sudo apt upgrade -y
>> >> # reboot if a new kernel was installed by apt upgrade
>> >> sudo reboot
>> >> # install qgis-server and apache web server
>> >> sudo apt install qgis-server apache2 libapache2-mod-fcgid
>> >> # enable apache fcgi and cgi
>> >> sudo a2enmod fcgi cgi
>> >> sudo systemctl restart apache2
>> >> # in a web browser you should now get an XML document from the
>> following request
>> http://IP-ADDRESS-OR-HOST-NAME/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
>> >> And 3 more steps got me a map
>> >> # load some test data
>> >> wget https://github.com/qgis/QGIS-Training-Data/archive/v2.0.zip
>> >> sudo apt install unzip
>> >> unzip v2.0.zip
>> >> # in a web browser you should get a map from the following request
>> http://IP-ADDRESS-OR-HOST-NAME/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities&MAP=/home/ubuntu/QGIS-Training-Data-2.0/exercise_data/qgis-server-tutorial-data/world.qgs&LAYERS=countries&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&CRS=EPSG:4326&WIDTH=400&HEIGHT=200&BBOX=-90,-180,90,180
>> >> The tutorial tries to cover a lot of ground, maybe too much. And the 8
>> steps above certainly don't cover enough for a production server. But it's
>> quite unfair to say that "QGIS Server is not ready for production". As
>> Donovan pointed out, there are a lot of moving parts and you have to have
>> some proficiency with all of them if you are doing it on your own.
>> >> The basic principle is that QGIS Server is serving WMS, WFS, WCS
>> requests via CGI (or Fast-CGI). Apache, Ngix, IIS, Tomcat all can serve CGI
>> and Fast-CGI. Pick whatever operating system and web server you're the most
>> proficient with. Install QGIS Server, start with the simplest configuration
>> that you can, as I did above. Then start tuning it to your needs. If you
>> run into problems ask for help on the list or
>> https://gis.stackexchange.com/ with specific details as to what the
>> problem is.
>> >> Richard W. Greenwood
>> >> www.greenwoodmap.com
>> > GisKraft, Geodatakonsult
>> > Mats Elfström, Marsvinsholms stationsväg 80, 271 93 Ystad, Sweden
>> > tel: +46 70 595 39 35 / www.giskraft.se
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> *GisKraft*, Geodatakonsult
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211018/be8f2458/attachment.html>
