[Qgis-user] CSV Import records missing on map
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Sun Sep 26 17:38:56 PDT 2021
I have never used DMS, but rather Degrees in Decimals so perhaps that is the problem. Make sure what is currently imported is actually in the correct place in DMS.
Normally, problems with csv is related to empty field or extra separators. Look at the file in notepad or notepad ++ and eliminate to problematic characters to make sure columns are Perfectly aligned. This can be hard to find if the separator is a space character.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 26 sept. 2021 à 16:48, Peter Devanney <peter at devanney.ca> a écrit :
> Hello
> I have an issue I have never run into before.
> I am adding a delimited text (CSV) layer and only some of the records appear on the map. 36/118 records show. The rest do not show but are still in the attribute table.
> When I run add geometry attributes or do an export to .shp I only see the 36 records that showed up on the map.
> All records look identical in the source CSV. I cannot see any difference that would explain why one record imported successfully with geometry attributes and the others didn't.
> The CSV file has separate Lat and Long columns with coordinates in DMS
> Latitude Longitude
> N45 45 56.1 W075 27 51.3
> I am running 3.16.8 on OS X Big Sur 11.5.2
> Scratching my head as to why some records import ok and the others do not, even though all show up in the attribute table.
> thanks
> Peter Devanney
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210926/bf038602/attachment.html>
