[Qgis-user] CSV Import records missing on map
    Peter Devanney
    peter at devanney.ca
    Mon Sep 27 11:32:06 PDT 2021
Nicolas
Thanks for the tip. I did check in Textedit and only see commas as
separator values and the DMS all look formatted the same.
This is also my first time having to use DMS - I usually use D.D without
any issues.
Peter
On Sun, Sep 26, 2021 at 8:39 PM Nicolas Cadieux <njacadieux.gitlab at gmail.com>
wrote:
> Hi,
> I have never used DMS, but rather Degrees in Decimals so perhaps that is
> the problem.  Make sure what is currently imported is actually in the
> correct place in DMS.
> Normally, problems with csv is related to empty field or extra
> separators.  Look at the file in notepad or notepad ++ and eliminate to
> problematic characters to make sure columns are Perfectly aligned. This can
> be hard to find if the separator is a space character.
> Nicolas Cadieux
> https://gitlab.com/njacadieux
> Le 26 sept. 2021 à 16:48, Peter Devanney <peter at devanney.ca> a écrit :
> Hello
> I have an issue I have never run into before.
> I am adding a delimited text (CSV) layer and only some of the records
> appear on the map. 36/118 records show. The rest do not show but are still
> in the attribute table.
> When I run add geometry attributes or do an export to .shp I only see the
> 36 records that showed up on the map.
> All records look identical in the source CSV. I cannot see any difference
> that would explain why one record imported successfully with geometry
> attributes and the others didn't.
> The CSV file has separate Lat and Long columns with coordinates in DMS
> Latitude Longitude
> N45 45 56.1 W075 27 51.3
> I am running 3.16.8 on OS X Big Sur 11.5.2
> Scratching my head as to why some records import ok and the others do not,
> even though all show up in the attribute table.
> thanks
> Peter Devanney
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210927/b54777ce/attachment-0001.html>
