[Qgis-user] How to make joined fields editable?
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Sun May 15 04:38:18 PDT 2022
I am unsure of what is happening here. I don’t use postgis tables and I normally use csv as join table (therefore not editable from the start). You can however save the 2 joined table as a gpkg under a new name. Just use the export dialogue and both will be saved. This will make a new editable file if you use an editable format as an export file format and will get you out of this bind.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 15 mai 2022 à 04:25, Roland Berger via Qgis-user <qgis-user at lists.osgeo.org> a écrit :
> Hi, I have a point vector layer A and joined some fields from a table B. Now I would like to edit values in B by looking at the attribute table of A. In the 'Edit Vector Join' Dialog' of A I have ticked the checkbox 'Editable join layer'. If I now try to edit the attribute table of A the joined fields of B are shown but still not editable.
> What does this checkbox 'Editable join layer' in the 'Edit Vector Join' Dialog really do?
> What do I have to do to make joined fields editable?
> Thanks for any help.
> Roland
> Remarks:
> Layer A is in a Postgis database. Table B is in a Geopackage File (gpkg)
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220515/d3530e2e/attachment.htm>
