[Qgis-user] How to make joined fields editable?
Harrissou s.
delazj at gmail.com
Sun May 15 07:00:05 PDT 2022
I never tried to edit a joined so I can only point you to the docs https://docs.qgis.org/3.22/en/docs/user_manual/working_with_vector/vector_properties.html#joins-properties that seems to confirm your assumption about that checkbox. Pay attention to the type of icon next to fields (layer?) to find out what could be the reason of the failure.
Hope that helps,
Regards,
Harrissou
Le 15 mai 2022 13:38:18 GMT+02:00, Nicolas Cadieux via Qgis-user <qgis-user at lists.osgeo.org> a écrit :
>Hi,
>I am unsure of what is happening here. I don’t use postgis tables and I normally use csv as join table (therefore not editable from the start). You can however save the 2 joined table as a gpkg under a new name. Just use the export dialogue and both will be saved. This will make a new editable file if you use an editable format as an export file format and will get you out of this bind.
>Nicolas Cadieux
>https://gitlab.com/njacadieux
>> Le 15 mai 2022 à 04:25, Roland Berger via Qgis-user <qgis-user at lists.osgeo.org> a écrit :
>> Hi, I have a point vector layer A and joined some fields from a table B. Now I would like to edit values in B by looking at the attribute table of A. In the 'Edit Vector Join' Dialog' of A I have ticked the checkbox 'Editable join layer'. If I now try to edit the attribute table of A the joined fields of B are shown but still not editable.
>> What does this checkbox 'Editable join layer' in the 'Edit Vector Join' Dialog really do?
>> What do I have to do to make joined fields editable?
>> Thanks for any help.
>> Roland
>> Remarks:
>> Layer A is in a Postgis database. Table B is in a Geopackage File (gpkg)
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220515/98154eb0/attachment.htm>
