[Qgis-user] Error export .shp to .gpx
Mike Breiding - Morgantown WV
epicroadtrips at gmail.com
Sun May 29 03:02:35 PDT 2022
On 5/28/2022 7:29 PM, Thayer Young via Qgis-user wrote:
> If you want to try gpx extensions you can scroll down in the QGIS
> "Export" GPX dialog, near the bottom in the "Datasource Options" you
> should change "GPX_USE_EXTENSIONS" to "yes".
> There may be other plugins that others can tell you about.
> -Thayer
Thanks, Thayer and all.
I was able to convert to a GPX with the instructions above.
But, now there are other problems which I will present under another topic.
WV-Mike
