[Qgis-user] adding a layer from a zipped file
Stephen Sacks
ssacks456 at gmail.com
Mon May 30 07:37:24 PDT 2022
Hi Richard,
Your "wild guess" is exactly right. I tested it. I copied file
"GardenA.qml" into the same folder where "GardenA.zip" is located. Then
told QGIS to add vector layer "GardenA.zip". It added layer "GardenA"
using the correct color and labels. A similar test added layer
"GardenAtrees.zip" with the correct svg symbol.
You've solved the mystery. THANK YOU.
I'm not happy with the resulting layer name ("GardenA - GardenA.shp"
instead of just "GardenA") so I'll have to change all the layer names.
But I can write a Python script to do that.)
I've never used geopackages. Something new for me to learn.
Cheers,
Steve
On 5/30/2022 3:44 AM, Richard Duivenvoorde wrote:
> Hi Stephen,
> Wild guessing here (not tested).
> I think: GDAL is responsible for loading the data from shape OR zipped
> shape
> QGIS is responsible for loading of a corresponding qml file.
> Normally, when QGIS (using GDAL) loads foo.shp, it will check if there
> is a foo.sld or foo.qml NEXT to it, and if so, uses it to STYLE the data.
> Now if you zipped foo.shp+files into foo.zip...
> Maybe QGIS is clever enough to ALSO look INTO the zip (and if not,
> this would be a nice Feature Request...)
> But else: try to put foo.qml next to the foo.zip
> But if you zipped the files into bar.zip...
> Then I would try to put a 'bar.qml' next to it (and hoping that QGIS
> decides that it has the same 'base name'.
> If all that fails: I would create a Feature Request for it (or start
> using Geopackages ...)
> Note that using geopackages, you also have 1 file, and you can save
> style INTO the geopackage (and even put more layers+styles into it etc
> etc).
> Regards,
> On 5/29/22 19:02, Stephen Sacks via Qgis-user wrote:
>> Hi Phil,
>> Thanks for your reply. This morning I updated my QGIS from
>> version 3.16.3 to version 3.22.7 . With complete optimism, I
>> reloaded several layers from zipped shapefiles, but alas the problem
>> remains: polygons appear in random colors and without labels and
>> point layers have dots instead of the svg icons they have when I load
>> the same layers from the un-zipped six shapefile files. When I
>> examine the zip files with Windows File Explorer, I see the .qml
>> files are there and uncorrupted.
>> I'm using a five-year-old plain vanilla Dell desktop running
>> 64-bit Windows 10.
>> I did the zipping with Thunderbird's Archive. Then, separately,
>> zipped one layer with Windows File Explorer zipper. Same result.
>> Am I doing something wrong? Shall I try updating to QGIS 3.24
>> ? Is it "stable"? What does it mean that version 3.22 is "stable"?
>> Steve
>> On 5/29/2022 12:03 AM, Phil Wyatt wrote:
>>> Hi Stephen,
>>> You might let us know your operating system and which version of
>>> QGIS you are using because it works as you desire in the latest
>>> development (3.24.3) and Long Term Release versions (3.22.7). It
>>> may just be a matter of updating QGIS.
>>> Cheers - Phil
>>> *From:*Qgis-user <qgis-user-bounces at lists.osgeo.org> *On Behalf Of
>>> *Stephen Sacks via Qgis-user
>>> *Sent:* Sunday, 29 May 2022 5:29 AM
>>> *To:* qgis forum <qgis-user at lists.osgeo.org>
>>> *Subject:* [Qgis-user] adding a layer from a zipped file
>>> When I write a layer as a shape file, it appears on my C: drive as
>>> six files, all with the same name but different extensions. Then I
>>> zip those six into a single file (xxx.zip). When I reload that
>>> layer from the zip file (Layer > AddLayer > VectorLayer > File >
>>> Dataset > xxx.zip), QGIS is almost smart enough to restore the layer
>>> correctly. The polygon features are in the right place and their
>>> attribute table is correct. *My problem* is that it ignores one of
>>> the six files, the "style" file (xxx .qml) which specifies color,
>>> labeling, and symbol). Do I have to unzip before restoring layer
>>> xxx ? I know I could open the layer's properties and use Style >
>>> Load Style from file xxx.qml . But when I'm restoring several
>>> layers that's a lot of key strokes (and may require that I unzip).
>>> It seems to me that this shouldn't be necessary. [I encounter the
>>> same problem with point layers and polygon layers.]
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220530/9c965668/attachment.htm>
