[Qgis-user] [EXTERNAL] Re: Geopackage slow on NAS if not read-only
Gabriel De Luca
pablogabrieldeluca at gmail.com
Thu Mar 16 07:38:22 PDT 2023
Hi Árni,
You can try setting the SQLITE_USE_OGR_VFS=YES configuration option, as
mentioned at https://github.com/qgis/QGIS/issues/27899.
Be sure to read the implications of changing the default (NO) option:
https://gdal.org/drivers/vector/sqlite.html#configuration-options
You can change the config option in a environment variable or a config
file: https://gdal.org/user/configoptions.html#configuration-options
Regards,
Gabriel
El jue, 16 mar 2023 a la(s) 11:08, Árni Geirsson via QGIS-User (
qgis-user at lists.osgeo.org) escribió:
> I do appreciate the good advice to use DBMS, I am doing that too and
> understand the advantages. I would never consider using a geopackage if I
> thought that multiple people would want to edit them at the same time. But
> that is not the case and that is not my problem. Sometimes, I just want to
> keep geodata in a file on a network share and run the risk (in my case
> insignificant) that the file will be corrupted by multi user access. This I
> can do with shapefiles, but unlike the shapefiles, I have to set the
> read-only flag on the geopackages stored on the network to get decent
> rendering speed, without ever wanting to edit the files. I think wanting to
> use file based storage for geodata in a networked environment is not
> unreasonable, even if there is some danger of corruption. All file based
> formats are probably subject to that risk, but I repeat, that issue is not
> what I am talking about, just the rendering speed of data in a geopackage
> that is not set to read-only.
> I suspect that there is no solution and that I will just have to live with
> this - as I have done for years. It is just a bit annoying. And I am
> surprised how little it is discussed.
> Árni
> On Thu, 16 Mar 2023 at 13:46, Sadowski Jarosław via QGIS-User <
> qgis-user at lists.osgeo.org> wrote:
>> +1
>> Don’t use file formats to edit by multiple users. I was occurring some
>> critical problems, as for example disappearing objects from database or
>> LOOOOONG read for first time ☹
>> Use PostgreSQL or other solutions like:
>> Mergin Maps: Collect, Store and Analyze your Geo-Data Easily
>> <https://merginmaps.com/>
>> GIS Support » GIS.Box (gis--support-pl.translate.goog)
>> <https://gis--support-pl.translate.goog/gis-box/?_x_tr_sl=pl&_x_tr_tl=en&_x_tr_hl=pl&_x_tr_pto=wapp>
>> *_________________________________*
>> *Jarosław Sadowski*
>> Kierownik Zespołu ds. Ochrony Środowiska | *Biuro Strategii i
>> Planowania, Projektowania i Inżynierii Podprogramu Kolejowego*
>> *Environmental Protection Team Leader **| Railway Subprogramme Strategy
>> & Planning, Design & Engineering Department*
>> e: jaroslaw.sadowski at cpk.pl
>> m: +48 532 720 230
>> *From:* QGIS-User <qgis-user-bounces at lists.osgeo.org> *On Behalf Of *Bo
>> Victor Thomsen via QGIS-User
>> *Sent:* Thursday, March 16, 2023 2:35 PM
>> *To:* qgis-user at lists.osgeo.org
>> *Subject:* Re: [Qgis-user] [EXTERNAL] Re: Geopackage slow on NAS if not
>> read-only
>> UWAGA: Ta wiadomość pochodzi spoza CPK Sp. z o.o. Proszę pomóż zadbać o
>> bezpieczeństwo naszej organizacji. Zastanów się, zanim otworzysz link lub
>> załącznik.
>> When any user on your network access the geopackage layer and (maybe
>> unnecessarily) puts the layer in edit mode, there will be created 2 extra
>> files in the same directory as the gpkg file resides in. And QGIS behaves
>> different regarding *both* read and write operations when these file are
>> present. This is probably the explanation of the longer reading times, even
>> if nobody actually is editing the layer. When the user stops the editing
>> mode for the layer, the 2 files disappear.
>> You can check if this is the explanation:
>> 1. Open the gpkg layer in read mode on one computer, check the access
>> speed of the same layer on *another* computer.
>> 2. Set the layer in edit mode on the first computer, check the access
>> speed to the layer on the second computer
>> 3. Revert the edit mode on the first computer, check the access speed
>> to the layer on the second computer.
>> I am guessing, that situations 1 and 3 are fast, while situation 2 is
>> slow.
>> First of all: Never, ever try to implement some kind of multi-user
>> editing on a file based format, where the file resides on a networked
>> drive. It will never, ever work reliably. At some point 2 users will try to
>> edit the same layer at the same time and it will go kaboom (I can read from
>> your mails that you are aware about this). This goes for - probably - every
>> file based format on a network drive.
>> Secondly: What about making the gpkg file read-only at the network share
>> level for most of the users. And only granting write access to the gpkg
>> file for certain users that are instructed in *not* setting the layer in
>> edit mode unless it's strictly necessary ?
>> The best solution: Install Postgres/PostGIS on your NAS
>> Med venlig hilsen / Best regards
>> Bo Victor Thomsen
>> Den 16-03-2023 kl. 13:49 skrev Árni Geirsson via QGIS-User:
>> Thank you for the various responses.
>> Let me be clear that what I am griping about is not the locking aspect
>> that would allow multiple users to edit without conflict. I fully
>> understand that the geopackage is not safe for that, nor is the shapefile
>> and perhaps also the file geodatabase. In my case, the likelihood of two
>> people wanting to edit the same geopackage is negligible, so I take my
>> chances. My only gripe is the rendering speed of larger geopackages on a
>> shared network, if they are not set specifically to read-only. That is not
>> a problem with the shapefile and I think probably not with a file
>> geodatabase. I am a long time user of geopackages in a networked
>> environment and I will continue to use them - they are great - there is
>> just this problem of rendering speed over a network.
>> Árni
>> On Thu, 16 Mar 2023 at 12:33, Sebastian Gutwein <bas at rdgland.com> wrote:
>> This is all beyond my expertise but I have also struggled with the
>> effective use of gpkg’s. In my case over google drive.
>> Here is what SQLite (the underlying software for gpkgs) says about using
>> a SQLite database on a network:
>> https://www.sqlite.org/useovernet.html
>> <https://eur06.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.sqlite.org%2Fuseovernet.html&data=05%7C01%7Cjaroslaw.sadowski%40cpk.pl%7Cd767a39352fb48744fbc08db26235086%7Cfa798250ca0b4a1bb47381cff4a1752b%7C1%7C0%7C638145705353555137%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=gF5jBExKrp2Hlks%2FQEHefiiG0FJFhqAG8fJ0VxBs4Kc%3D&reserved=0>
>> I hope that someday someone implements a system that allows this to work
>> efficiently as gpkgs are better in many respects than shapefiles. Perhaps
>> Geodiff could be part of that solution.
>> https://github.com/MerginMaps/geodiff
>> <https://eur06.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2FMerginMaps%2Fgeodiff&data=05%7C01%7Cjaroslaw.sadowski%40cpk.pl%7Cd767a39352fb48744fbc08db26235086%7Cfa798250ca0b4a1bb47381cff4a1752b%7C1%7C0%7C638145705353555137%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=bcngOeZeGv1iT%2BEEOV2Vtf3%2FZRXxYLBvgRuX0SMFOdI%3D&reserved=0>
>> On Thu, Mar 16, 2023 at 8:04 AM Árni Geirsson via QGIS-User <
>> Hi Jorge
>> I understand what you are pointing at and I use databases such as
>> Postgres/PostGIS also with good results. The thing is that working with
>> data in files sometimes has advantages and that is certainly how shapefiles
>> have been used. The geopackage has been suggested as a replacement for the
>> shapefile in the context of regular QGIS usage without any caveat saying
>> that geopackages only replace the storage and transfer role of shapefiles
>> and that geopackages should not be used for editing in a shared
>> environment, as is perfectly possible with shapefiles and widely practiced.
>> Not all users have access to database systems such as Postgres. I'm just
>> looking for some clarity on best practices for the common scenario of
>> working with QGIS using file based data in a network environment.
>> Árni
>> On Thu, 16 Mar 2023 at 11:47, Jorge Gustavo Rocha via QGIS-User <
>> Hi,
>> For data storage and manipulation databases are suitable. Files are not.
>> Geopackages are wonderful to transfer data between systems or to archive
>> an entire project (snapshot of data, styles and the project itself).
>> Regards,
>> Jorge
>> On 16/03/23 11:30, Árni Geirsson via QGIS-User wrote:
>> Thank you Jarosław. Isn't it strange that this was discussed 5 years ago
>> and SMB file sharing is very common? Would a linux based NAS be able to use
>> another protocol? What are my options for file based data sharing in QGIS?
>> Abandoning geopackages is not a realistic option for me, but I could get a
>> different kind of NAS unit, if that helps, what kind then? What amazes me
>> is how little I see this discussed. There was a message in this thread this
>> morning from Thomas Struller, but I am not sure it is about the same root
>> problem, maybe Thomas can elaborate.
>> Should this perhaps be discussed in another forum, closer to the
>> development of geopackage/sqlite?
>> Árni Geirsson
>> On Thu, 16 Mar 2023 at 09:52, Sadowski Jarosław <jaroslaw.sadowski at cpk.pl>
>> wrote:
>> Long story short: gpkg is bad idea for network drives as SMB/NAS etc
>> Sources:
>> Write-Ahead Logging (sqlite.org)
>> <https://eur06.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.sqlite.org%2Fwal.html%23advantages&data=05%7C01%7Cjaroslaw.sadowski%40cpk.pl%7Cd767a39352fb48744fbc08db26235086%7Cfa798250ca0b4a1bb47381cff4a1752b%7C1%7C0%7C638145705353555137%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=vrWFTUkAozdYRmNNtVRiMz5YiGTzAso2UQDgEzkzr6w%3D&reserved=0>
>> writing gpkg and sqlite on samba shares fails · Issue #628 · r-spatial/sf
>> · GitHub
>> <https://eur06.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2Fr-spatial%2Fsf%2Fissues%2F628&data=05%7C01%7Cjaroslaw.sadowski%40cpk.pl%7Cd767a39352fb48744fbc08db26235086%7Cfa798250ca0b4a1bb47381cff4a1752b%7C1%7C0%7C638145705353555137%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=aC2PYy3vqIWzu3XXWMjhggZawmN9dXQcunqObizOQNY%3D&reserved=0>
>> *Jarosław Sadowski*
>> *Environmental Protection Team Leader | Railway Subprogramme Strategy &
>> m: +48 532 720 230
>> Centralny Port Komunikacyjny Sp. z o.o. z siedzibą w Warszawie, Aleje
>> Jerozolimskie 142B, 02-305 Warszawa
>> <https://eur06.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.google.com%2Fmaps%2Fsearch%2FAleje%250D%250A%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2BJerozolimskie%2B142B%2C%2B02-305%2BWarszawa%3Fentry%3Dgmail%26source%3Dg&data=05%7C01%7Cjaroslaw.sadowski%40cpk.pl%7Cd767a39352fb48744fbc08db26235086%7Cfa798250ca0b4a1bb47381cff4a1752b%7C1%7C0%7C638145705353555137%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=bHlRUwTSYp%2F9iSSPfRvPoxdo8godq3BHOpLOleYg4AI%3D&reserved=0>;
>> nr KRS 0000759991, Sąd Rejonowy dla m.st
>> <https://eur06.safelinks.protection.outlook.com/?url=http%3A%2F%2Fm.st%2F&data=05%7C01%7Cjaroslaw.sadowski%40cpk.pl%7Cd767a39352fb48744fbc08db26235086%7Cfa798250ca0b4a1bb47381cff4a1752b%7C1%7C0%7C638145705353555137%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=YC4lvRzDW7KLvQ9XNwKkx1LegwU4YpfZG7rm9jtxd1s%3D&reserved=0>.
>> Warszawy, XII Wydział Gospodarczy Krajowego Rejestru Sądowego; NIP
>> 701-08-94-497; REGON 381918620; kapitał zakładowy 1.277.500.000,00 zł
>> Administratorem danych osobowych przekazanych przez Panią/Pana m.in. w
>> korespondencji mailowej jest Centralny Port Komunikacyjny Sp. z o.o. z
>> siedzibą w Warszawie. Przetwarzamy dane osobowe zgodnie z przepisami
>> ogólnego rozporządzenia o ochronie danych (RODO), więcej informacji na ten
>> temat znajduje się w zakładce Polityka Prywatności oraz w Klauzuli
>> informacyjnej na stronie internetowej www.cpk.pl
>> <https://eur06.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.cpk.pl%2F&data=05%7C01%7Cjaroslaw.sadowski%40cpk.pl%7Cd767a39352fb48744fbc08db26235086%7Cfa798250ca0b4a1bb47381cff4a1752b%7C1%7C0%7C638145705353555137%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=uHuaO4hwhdJcCM8YgFGlTI%2F9jUJYElxlNC%2FGEanwNms%3D&reserved=0>
>> Treści zawarte w niniejszej wiadomości i załącznikach do niej stanowią
>> Tajemnicę Przedsiębiorstwa w rozumieniu ustawy z dnia 16 kwietnia 1993 r. o
>> zwalczaniu nieuczciwej konkurencji. Jeśli otrzymałeś tę wiadomość przez
>> pomyłkę, bezzwłocznie skontaktuj się z nadawcą wiadomości oraz usuń jej
>> treść.
>> Centralny Port Komunikacyjny Sp. z o.o. with headquarters in Warsaw,
>> Aleje Jerozolimskie 142B, 02-305 Warsaw
>> <https://eur06.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.google.com%2Fmaps%2Fsearch%2FWarsaw%2C%2BAleje%250D%250A%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2B%2BJerozolimskie%2B142B%2C%2B02-305%2BWarsaw%3Fentry%3Dgmail%26source%3Dg&data=05%7C01%7Cjaroslaw.sadowski%40cpk.pl%7Cd767a39352fb48744fbc08db26235086%7Cfa798250ca0b4a1bb47381cff4a1752b%7C1%7C0%7C638145705353555137%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=EvNnBNzkjbcbydKALT6iRX3LBul5gv3JY1CWwu%2FoREg%3D&reserved=0>;
>> KRS No. 0000759991, District Court for the Capital City of Warsaw, 12th
>> Commercial Department of the National Court Register; NIP 701-08-94-497;
>> REGON 381918620; share capital of PLN 1.277.500.000,00.
>> The personal data controller of the personal data provided by you, among
>> others, in the e-mail correspondence, is Centralny Port Komunikacyjny Sp. z
>> o. o. based in Warsaw. The personal data is processed by us in accordance
>> with the provisions of the General Data Protection Regulation (GDPR), for
>> further information please read the Privacy Policy tab and the Information
>> Clause on the www.cpk.pl
>> website.
>> The content of this message and its attachments constitute the Business
>> Secret within the meaning of the Act of 16 April 1993 on combating unfair
>> competition. If you received this message by mistake, contact the sender of
>> the message immediately and delete its content
>> *From:* QGIS-User <qgis-user-bounces at lists.osgeo.org> *On Behalf Of *Árni
>> *Sent:* Thursday, March 16, 2023 10:18 AM
>> *To:* jhubbslist at att.net
>> *Cc:* qgis-user at lists.osgeo.org
>> *Subject:* [EXTERNAL] Re: [Qgis-user] Geopackage slow on NAS if not
>> read-only
>> lub załącznik.
>> Yes, as far as I know, the NAS unit uses SMB as the file sharing
>> protocol. I used another NAS from QNAP before this one, also using SMB and
>> with the same problem. I thought pretty much all of the Linux based NAS
>> units were using SMB and if that is the problem, it should be widespread,
>> but I don't see any signs of that. Is SMB a problem for geopackage?
>> I did a quick test in QGIS: A dataset of 178.000 line features is
>> rendered in about 1 second from a read only geopackage. When I remove the
>> read only flag, it is rendered in about 5 seconds.
>> If I store the geopackage on the local hard drive, the problem
>> disappears, read-write or read-only does not matter.
>> I have had suspicions about SMB being part of the problem but I don't
>> know enough about file access deep down in the operating system to
>> understand it.
>> Árni Geirsson
>> On Thu, 16 Mar 2023 at 01:45, jhubbslist--- via QGIS-User <
>> Árni -
>> Are you using SMB/CIFS to access this NAS, and are you using wifi or
>> Ethernet to connect to it?
>> - Jeff
>> On 3/15/23 3:30 PM, Árni Geirsson via QGIS-User wrote:
>> Hello all QGIS and geopackage users.
>> I store my geopackages on a Synology RackStation NAS unit, like all other
>> documents that are kept on a shared drive in the office. For larger
>> datasets, the rendering is very slow, unless I open the properties dialog
>> for the file in Windows and check the read only box. After that, the
>> features are rendered blazingly fast. Nothing else is changed to see the
>> dramatic difference in the rendering speed. Luckily, I don't need to edit
>> many of the larger datasets, such as road networks and elevation contours
>> and the geopackage can be kept read only. Shapefiles are not affected.
>> What explains this and does anyone know how to solve the problem?
>> Do other users experience this?
>> Árni Geirsson
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://eur06.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fqgis-user&data=05%7C01%7Cjaroslaw.sadowski%40cpk.pl%7Cd767a39352fb48744fbc08db26235086%7Cfa798250ca0b4a1bb47381cff4a1752b%7C1%7C0%7C638145705353555137%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=zWL3lJDscTuLqjNO8Wi1oFcqS%2FsdczPZY3x1hiAYyBM%3D&reserved=0>
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://eur06.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fqgis-user&data=05%7C01%7Cjaroslaw.sadowski%40cpk.pl%7Cd767a39352fb48744fbc08db26235086%7Cfa798250ca0b4a1bb47381cff4a1752b%7C1%7C0%7C638145705353712104%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=mW4NbdtL2GFA1o2wNdAzIeEra7oa6XFo010WXMpypvU%3D&reserved=0>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://eur06.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fqgis-user&data=05%7C01%7Cjaroslaw.sadowski%40cpk.pl%7Cd767a39352fb48744fbc08db26235086%7Cfa798250ca0b4a1bb47381cff4a1752b%7C1%7C0%7C638145705353712104%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=mW4NbdtL2GFA1o2wNdAzIeEra7oa6XFo010WXMpypvU%3D&reserved=0>
>> Jorge Gustavo Rocha
>> Geomaster, LDA
>> "Take the open source journey with us"
>> VAT/NIF: PT 510 906 109
>> Phone: +351 253 257 173 (landline)
>> Mobile: +351 910 333 888 (cellular)
>> Rua Afonso Palmeira, 31, 7 <https://eur06.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.google.com%2Fmaps%2Fsearch%2FRua%2BAfonso%2BPalmeira%2C%2B31%2C%2B7%3Fentry%3Dgmail%26source%3Dg&data=05%7C01%7Cjaroslaw.sadowski%40cpk.pl%7Cd767a39352fb48744fbc08db26235086%7Cfa798250ca0b4a1bb47381cff4a1752b%7C1%7C0%7C638145705353712104%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=Gghx2QBaFcLS6wBLy1a9MuExneqWyKKIldi0ExKgwA4%3D&reserved=0> D
>> 4715-278 Braga
>> PORTUGAL
>> GPS 41.54627, -8.40432
>> Sent from a phone. Amazing! But possibly garbled. Sebastian Gutwein
>> Regenerative Design Group 1 Chevalier Ave Greenfield MA Bas at rdgland.com
>> (631) 241-1018
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230316/33aaed5f/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230316/33aaed5f/attachment-0001.png>
More information about the QGIS-User
