[Qgis-user] Editing GPKG from network drive
jhubbslist at att.net
Tue Aug 13 05:20:21 PDT 2024
I was just going to say, I think it's situations like this why PostGIS
exists.
On 8/13/24 3:41 AM, Francesco Pelullo via QGIS-User wrote:
> Hi Simon,
> We're usually store data in .gpkg on network drive.
> Data access in read mode is very nice, also with dozen concurrent users.
> Instead, writing data in .gpkg on network drive can cause errors,
> specially if from two or more concurrent users.
> This is because of limits of SQLite format. In past, there was
> suggestions about a "semaphore" file that prevents to edit .gpkg file,
> if another user is editing.
> My suggestion is: split .gpkg in smallest parts, assign every area (or
> part) to a user, merge parts at the end.
> Or, use PostGIS.
> Regards
> Francesco
> Il mar 13 ago 2024, 09:30 Simon Gröchenig via QGIS-User
> <qgis-user at lists.osgeo.org> ha scritto:
> Hi list,
> a project partner "sometimes" struggles to edit GPKGs that are
> saved on a network drive. Trying to modify the GPKG in QGIS
> results in the following error:
>> Provider errors: OGR error committing transaction:
>> sqlite3_exec(COMMIT) failed: disk I/O error
> No problems occur modifying the same GPKG when it is located on a
> local drive.
> I found the following 8-year-old qgis-user thread:
> https://qgis-user.osgeo.narkive.com/bjrGqIjn/something-to-think-about-geopackage-and-wal
> Is this thread related to the disk I/O error?
> I would also like to ask if GPKGs or SQLite-DBs are still unsave
> to use from network drives!? Is there any current information
> about this somewhere?
> Best regards
> Simon
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240813/f1decbb5/attachment.htm>
More information about the QGIS-User
