[Qgis-user] Create a polygon with a specific area size
Ujaval Gandhi
ujaval at spatialthoughts.com
Tue Aug 27 07:28:22 PDT 2024
If you 'Identify' the polygon, it will display the polygon Area in square meters
under the 'Derived' section. Let's call this X. If your desired area is Y,
the scaling factor is Y/X. Use this scaling factor and scale it using the
'Scale' tool in the Advanced Digitizing
toolbar. https://youtu.be/70CDATzucDY?si=diTLZ2CRg7oS_a0l&t=102
[https://mailtrack.io/l/88a50ea3fbf821334810b1ba5b294ba682f78a87?url=https%3A%2F%2Fyoutu.be%2F70CDATzucDY%3Fsi%3DdiTLZ2CRg7oS_a0l%26t%3D102&u=8747767&signature=a357935210c9ac24]
Ujaval Gandhi
Spatial Thoughts
www.spatialthoughts.com
[https://mailtrack.io/l/52c33efac5182270f8277a3a6800f91491bc8cb9?url=http%3A%2F%2Fwww.spatialthoughts.com&u=8747767&signature=8fa5bc10ee973263]
[data:image/gif;base64,R0lGODlhAQABAIAAAP///wAAACwAAAAAAQABAAACAkQBADs=3D]
On Tue, Aug 27, 2024 at 7:18 PM Nicole Stoffels via QGIS-User
<qgis-user at lists.osgeo.org> wrote:
> Dear all,
> I want to create a polygon of a specific size. Currently I am working rather
> "hands on". As long as it is a rectangle and I provide either length or width,
> I can calculate the other one and do a construction with the advanced
> digitizing tool. But is there a way, that I construct a more complex polygon
> and define the area beforehand or scale it to a certain area afterwards. To my
> understanding the polygon scaling requires a factor. I cannot scale to a
> certain area size in square meters. Is there another function I haven't found
> yet?
> I am using QGIS 3.34.4.
> Best regards and thank you so much in advance!
> Nicole Stoffels
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org [QGIS-User at lists.osgeo.org]
> [https://lists.osgeo.org/mailman/listinfo/qgis-user]
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240827/2f650999/attachment.htm>
More information about the QGIS-User
