[Qgis-user] Create a polygon with a specific area size
    Andrea Giudiceandrea
    andreaerdna at libero.it
    Tue Aug 27 09:13:31 PDT 2024
> Ujaval Gandhi ujaval at spatialthoughts.com
> Tue Aug 27 07:28:22 PDT 2024
> If you 'Identify' the polygon, it will display the polygon Area in square meters
> under the 'Derived' section. Let's call this X. If your desired area is Y,
> the scaling factor is Y/X. Use this scaling factor and scale it using the
> 'Scale' tool in the Advanced Digitizing toolbar.
Hi all,
AFAIK the correct scaling factor to use is not Y/X, but the square root
of Y/X instead.
Regards.
Andrea
More information about the QGIS-User
