[Qgis-user] QGis on a Mac
Richard Duivenvoorde
rdmailings at duif.net
Thu Aug 29 22:45:51 PDT 2024
From you message it is not clear to me what you want/need.
so you have a folder with 150000 png tiles (in what structure)?
Downloaded as OS Opendata? Or created yourself within QGIS?
And you want to SERVE those as an local XYZ service, so QGIS can read them?
The folder is a sort of 'data cache' for a Map or Webserver.
I think that depends on the structure of that folder, if an Webserver (or some small python script) is enough.
But for bigger dataset the amount of files in a directory was to big for the Operating System.
So different tiling standards evolved, putting the images on disk in different structures...
For small dataset you could maybe just create the x/y/z structure on disk.
Or that you need to run some server like MapProxy (of newer kids on the block) running on your machine.
But, I think, you will always need some kind of server-process running.
Only if your data is in a true x,y,z structure and QGIS could handle a file:/home/foo/data/{z}/{x}/{y}.pbf url that would work.
mmm, this says it is possible (mind the max and min Z):
https://gis.stackexchange.com/questions/397040/loading-tiles-from-local-tms-using-xyz-tiles-in-qgis
Maybe best if you play around a little first with the 'Generate XYZ tiles'-processing script for a small dataset, and see if that looks like your dir?
Regards,
On 8/29/24 15:07, Don Williams via QGIS-User wrote:
> Hi all,
> Really struggling to work out what the path should be to bring in 150,000 png tiles based in a folder called OS Opendata on a Mac into xyz tiles in QGis?
> Probably asked a million times but all I see in the help pages is to use a url but these all reside on the hard-drive?
> Thank you
> Don
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
More information about the QGIS-User
