[Qgis-user] [EXTERNAL] Re: Unable to load Base maps in QGIS
    Hugh Kelley
    hghklly at gmail.com
    Thu Apr 10 02:42:38 PDT 2025
Hi, I believe this is a reported and fixed issue.
https://github.com/qgis/QGIS/issues/60807
Hugh
On Thu, Apr 10, 2025, 04:43 Phil Wyatt via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Hi Krishna,
> If you right click on the layer and “zoom to layer” does it appear?
> Might I also suggest that you upgrade to the latest Long Term Release
> 3.40.5 and see if that fixes things.
> https://qgis.org/download/
> Cheers - Phil
> *From:* QGIS-User <qgis-user-bounces at lists.osgeo.org> *On Behalf Of *Krishna
> Konduru - VAL via QGIS-User
> *Sent:* Wednesday, 9 April 2025 10:11 PM
> *To:* qgis-user at lists.osgeo.org; bernie.connors at unb.ca
> *Subject:* Re: [Qgis-user] [EXTERNAL] Re: Unable to load Base maps in QGIS
> Hi Bernie,
> Yes, I added the 'Quick Map Services plugin' from Plugins section in QGIS
> through QGIS Official Plugin Repository. I choose Google Hybrid or OSM as
> my basemap. Google Maps layer is checked in the Layers section. Both the
> Project CRS and Layer CRS are in EPSG 3857. But still it's a blank screen.
> Don't know what to do.
> Thanks,
> *Krishna Konduru *
> Berkshire Hathaway GUARD Insurance Companies
> *Krishna.Konduru at GUARD.com <Krishna.Konduru at GUARD.com>*
> 570-825-9900, ext.
> *From:* QGIS-User on behalf of Bernie Connors via QGIS-User
> *Sent:* Friday, March 28, 2025 06:31 PM
> *Subject:* [EXTERNAL] Re: [Qgis-user] Unable to load Base maps in QGIS
> *CAUTION: This email originated from outside of BH Insurance.*
> Krishna,
>         Are you using the Quick Map Services plugin?  It is a fast and
> easy way to add a basemap to your QGIS project.
> https://plugins.qgis.org/plugins/quick_map_services/
> Bernie.
> On Fri, Mar 28, 2025 at 7:33 AM Patrick Dunford via QGIS-User <
> What is a "Base Map"?
> A project has layers that are either loaded locally from file based
> sources, or remotely from some type of server (e.g. WMTS). The latter is
> subject to the assumption the owner of that server is willing to let you
> have access to the data you are attempting to connect to. In the case of
> both Google Maps and OSM, being the quoted examples, restrictions most
> certainly apply to connections to their servers. Such an issue would be
> irrelevant to this list since it would not be an issue caused by the Qgis
> software.
> On 28/03/25 02:16, Krishna Konduru - VAL via QGIS-User wrote:
> Hi,
> QGIS version: 3.34.15
> I am able to load and see shape file layers. But I am unable to see/load
> base maps like OSM, Google Maps etc. in QGIS. Could someone please help me
> find the issue. I am unable to find one.
>    - I tried restarting the software and system.
>    - Layers boxes are also checked in Layers panel.
>    - I tried mapping the same CRS between Project and Base map layer.
>    Tried with both EPSG: 3857 and EPSG: 4326. But still not able to see them.
> If anybody knows what the issue could be, please let us know.
> Thanks,
> *Krishna Konduru*
> ****** CONFIDENTIALITY NOTICE ******
> THIS E-MAIL, INCLUDING ANY ATTACHED FILES, MAY CONTAIN CONFIDENTIAL,
> PROPRIETARY AND/OR PRIVILEGED INFORMATION FOR THE SOLE USE OF THE INTENDED
> RECIPIENT(S). ANY REVIEW, USE, DISTRIBUTION, COPY OR DISCLOSURE BY OTHERS
> IS STRICTLY PROHIBITED. IF YOU ARE NOT THE INTENDED RECIPIENT (OR
> AUTHORIZED TO RECEIVE INFORMATION FOR THE RECIPIENT), PLEASE CONTACT THE
> SENDER AND DELETE ALL COPIES OF THIS MESSAGE.
> THANK YOU
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> Bernie Connors
> Fredericton, NB
> THANK YOU
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250410/9ced88f0/attachment.htm>
More information about the QGIS-User
