[Qgis-user] Qgis : Union process with aggregation/unique feature by overlay
celati Laurent laurent.celati at gmail.com
Tue Jul 22 07:07:14 PDT 2025
Good afternoon,
I have a very big polygonal layer (over 1 million objects). This layer
contains a 'gid' column whose values uniquely identify each object. There
is also a 'hierarchy_level_id' column:
this string column allowing to characterize the importance/priority level
of each object: 1, 2A, 2B, 3A, 3B.
My goal for this layer would be:
   - To perform a union process in the QGIS meaning:
   https://docs.qgis.org/3.40/en/docs/user_manual/processing_algs/qgis/vectoroverlay.html#union
   - In the result/output file, I want to create two new columns. The first
   column list the 'hierarchy_level_id' for each feature. And a second column
   would retrieve the maximum value of the 'hierarchy_level_id' for each
   feature.
In other words, for areas where there is one or more overlaps, I don't want
that my union result contains as many identical features as there are
features participating in this overlap. I want a single unique feature to
be created per overlap/overlapping area.
How can I perform this process with QGIS? Should I use the Qgis Union
process? Use the aggregate function? Or something else?
In advance, thanks so much.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250722/dd98cf20/attachment.htm>
More information about the QGIS-User mailing list
