[Qgis-user] FW: "Phantom" point in created layer
    chris hermansen
    clhermansen at gmail.com
    Tue Mar 25 08:41:59 PDT 2025
Nora and list,
On Tue, Mar 25, 2025 at 12:05 PM Nora Badenhorst via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> I am counting informal structures in our project areas.
> I created a shapefile layer and use the “Toggle editing – Add polygon
> feature”  function to add a point. Every structure gets a dot.
Why are you using "Add polygon feature" when your goal appears to be adding
points?
What is the geometry of your shapefile layer?  If you intend to have points
in it, then the geometry should be "point".
Chris Hermansen · clhermansen "at" gmail "dot" com
C'est ma façon de parler.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250325/cfd47984/attachment.htm>
More information about the QGIS-User
