[Qgis-user] Unable to load Base maps in QGIS
Patrick Dunford
enzedrailmaps at gmail.com
Fri Mar 28 03:18:50 PDT 2025
What is a "Base Map"?
A project has layers that are either loaded locally from file based
sources, or remotely from some type of server (e.g. WMTS). The latter is
subject to the assumption the owner of that server is willing to let you
have access to the data you are attempting to connect to. In the case of
both Google Maps and OSM, being the quoted examples, restrictions most
certainly apply to connections to their servers. Such an issue would be
irrelevant to this list since it would not be an issue caused by the
Qgis software.
On 28/03/25 02:16, Krishna Konduru - VAL via QGIS-User wrote:
> Hi,
> QGIS version: 3.34.15
> I am able to load and see shape file layers. But I am unable to
> see/load base maps like OSM, Google Maps etc. in QGIS. Could someone
> please help me find the issue. I am unable to find one.
> I tried restarting the software and system.
> Layers boxes are also checked in Layers panel.
> I tried mapping the same CRS between Project and Base map layer.
> Tried with both EPSG: 3857 and EPSG: 4326. But still not able to
> see them.
> If anybody knows what the issue could be, please let us know.
> Thanks,
> *Krishna Konduru *
> ****** CONFIDENTIALITY NOTICE ******
> THIS E-MAIL, INCLUDING ANY ATTACHED FILES, MAY CONTAIN CONFIDENTIAL,
> PROPRIETARY AND/OR PRIVILEGED INFORMATION FOR THE SOLE USE OF THE
> INTENDED RECIPIENT(S). ANY REVIEW, USE, DISTRIBUTION, COPY OR
> DISCLOSURE BY OTHERS IS STRICTLY PROHIBITED. IF YOU ARE NOT THE
> INTENDED RECIPIENT (OR AUTHORIZED TO RECEIVE INFORMATION FOR THE
> RECIPIENT), PLEASE CONTACT THE SENDER AND DELETE ALL COPIES OF THIS
> MESSAGE.
> THANK YOU
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250328/f090c398/attachment-0001.htm>
More information about the QGIS-User
