[Qgis-user] Unable to load Base maps in QGIS
Bernie Connors bernie.connors at unb.ca
Fri Mar 28 06:01:56 PDT 2025
Krishna,
        Are you using the Quick Map Services plugin?  It is a fast and easy
way to add a basemap to your QGIS project.
https://plugins.qgis.org/plugins/quick_map_services/
Bernie.
On Fri, Mar 28, 2025 at 7:33 AM Patrick Dunford via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> What is a "Base Map"?
> A project has layers that are either loaded locally from file based
> sources, or remotely from some type of server (e.g. WMTS). The latter is
> subject to the assumption the owner of that server is willing to let you
> have access to the data you are attempting to connect to. In the case of
> both Google Maps and OSM, being the quoted examples, restrictions most
> certainly apply to connections to their servers. Such an issue would be
> irrelevant to this list since it would not be an issue caused by the Qgis
> software.
> On 28/03/25 02:16, Krishna Konduru - VAL via QGIS-User wrote:
> Hi,
> QGIS version: 3.34.15
> I am able to load and see shape file layers. But I am unable to see/load
> base maps like OSM, Google Maps etc. in QGIS. Could someone please help me
> find the issue. I am unable to find one.
>    - I tried restarting the software and system.
>    - Layers boxes are also checked in Layers panel.
>    - I tried mapping the same CRS between Project and Base map layer.
>    Tried with both EPSG: 3857 and EPSG: 4326. But still not able to see them.
> If anybody knows what the issue could be, please let us know.
> Thanks,
> *Krishna Konduru *
> ****** CONFIDENTIALITY NOTICE ******
> THIS E-MAIL, INCLUDING ANY ATTACHED FILES, MAY CONTAIN CONFIDENTIAL,
> PROPRIETARY AND/OR PRIVILEGED INFORMATION FOR THE SOLE USE OF THE INTENDED
> RECIPIENT(S). ANY REVIEW, USE, DISTRIBUTION, COPY OR DISCLOSURE BY OTHERS
> IS STRICTLY PROHIBITED. IF YOU ARE NOT THE INTENDED RECIPIENT (OR
> AUTHORIZED TO RECEIVE INFORMATION FOR THE RECIPIENT), PLEASE CONTACT THE
> SENDER AND DELETE ALL COPIES OF THIS MESSAGE.
> THANK YOU
> QGIS-User mailing listQGIS-User at lists.osgeo.org
Bernie Connors
Fredericton, NB
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250328/42fa03b8/attachment.htm>
More information about the QGIS-User mailing list
