[Qgis-user] Update QGIS-Desktop
Gert-Jan van der Weijden - GISNederland gert-jan at gisnederland.nl
Sat Aug 15 02:45:23 PDT 2026
According to this page:
https://help.pdq.com/hc/en-us/articles/360043283251-Uninstalling-software-based-on-the-program-name
PDQ Deploy is able to run an uninstall based upon the name of the software.
In the example the match is made just by the registry key containing the
/displayname /of the program (starting with "QGis"),
one could easily extend that to match also on the publisher ("QGIS.org").
This way one can uninstall /all/ previous (side-by-side) versions.
regards,
Gert-Jan
On 8/14/2026 13:14, Johannes Kröger (WhereGroup) via QGIS-User wrote:
> Hi Ralf,
> by default QGIS installers install into independent and
> version-specific directories. You can adjust this, but if you would
> install into a previous version's directory, it would be a mess and
> also not unregister the old version in the OS registry, menus etc.
> The usual workflow is uninstalling the old version(s) independently
> from the installation of a new version. If you automate this as part
> of your deployment process or if you leave the older versions on your
> users' systems, is really your choice. For controlled end-user
> environments I would recommend adding the removal of the older version
> as part of the upgrade to a new version.
> User data is kept separately from the application so this is perfectly
> save. Newer QGIS versions might save things that are not supported by
> older versions into the user data though, so using multiple, different
> QGIS versions in parallel can lead to (smaller) issues. (QGIS 3.x and
> 4.x do NOT share their user data between the major versions 3 and 4,
> but all their subversions do share between themselves).
> Cheers, Hannes
> On 8/14/26 12:05, Blöcher, Ralf via QGIS-User wrote:
>> If I have version 3.34 installed and manually install version 3.44
>> over it, a second instance is also created. So this has nothing to do
>> with the software distribution solution.
>> Is there a way to download the latest QGIS LTR version and then
>> install it over an existing version?
>>   i.A. Ralf Blöcher
>> Informationstechnologie
>> E-Mail r.bloecher at traffiq.de
>>   traffiQ
>> Lokale Nahverkehrsgesellschaft Frankfurt am Main mbH
>> Stiftstr. 9 - 17
>> 60313 Frankfurt am Main
>> Geschäftsführer: Prof. Dr.-Ing. Tom Reinhold
>> Aufsichtsratsvorsitzender: Stadtrat Wolfgang Siefert
>> Amtsgericht Frankfurt am Main - HRB 42452
>> USt-ID: DE187077253
>> www.traffiQ.de
>> -----Ursprüngliche Nachricht-----
>> Von: QGIS-User <qgis-user-bounces at lists.osgeo.org> Im Auftrag von
>> Greg Troxel via QGIS-User
>> Gesendet: Freitag, 14. August 2026 11:26
>> An: Blöcher, Ralf via QGIS-User <qgis-user at lists.osgeo.org>
>> Betreff: Re: [Qgis-user] Update QGIS-Desktop
>> "Blöcher, Ralf via QGIS-User" <qgis-user at lists.osgeo.org> writes:
>>> I have a question about QGIS Desktop and updating to a new version.
>>> We install QGIS Desktop using a software distribution tool called
>>> PDQ Deploy. We use this to install the
>>> QGIS-OSGeo4W-3.34.11-1_LTR.msi file remotely on Windows clients.
>>> If I simply install the  new Version QGIS-OSGeo4W-3.44.12-1_LTR.msi
>>> file 'over' version 3.34, a second instance of QGIS is installed on
>>> the computer.
>>> But how can I remotely update version 3.34.11-1_LTR to version
>>> QGIS-OSGeo4W-3.44.12-1_LTR.msi using a software deployment tool
>>> without installing a second instance?
>> This question is about "PDQ Deploy", which appears to be a paid-for,
>> proprietary tool.  I suggest you address questions about PDQ Deploy
>> not doing what you want to your PDQ support contacts.
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260815/99834a09/attachment.htm>
More information about the QGIS-User mailing list
