[Qgis-user] Update QGIS-Desktop
Blöcher, Ralf
R.Bloecher at traffiQ.de
Mon Aug 17 00:13:30 PDT 2026
Hi Hannes,
thank you very much for the detailed information.
Best regards
Ralf
-----Ursprüngliche Nachricht-----
Von: QGIS-User <qgis-user-bounces at lists.osgeo.org> Im Auftrag von Johannes Kröger (WhereGroup) via QGIS-User
Gesendet: Freitag, 14. August 2026 13:14
An: qgis-user at lists.osgeo.org
Betreff: Re: [Qgis-user] Update QGIS-Desktop
Hi Ralf,
by default QGIS installers install into independent and version-specific directories. You can adjust this, but if you would install into a previous version's directory, it would be a mess and also not unregister the old version in the OS registry, menus etc.
The usual workflow is uninstalling the old version(s) independently from the installation of a new version. If you automate this as part of your deployment process or if you leave the older versions on your users'
systems, is really your choice. For controlled end-user environments I would recommend adding the removal of the older version as part of the upgrade to a new version.
User data is kept separately from the application so this is perfectly save. Newer QGIS versions might save things that are not supported by older versions into the user data though, so using multiple, different QGIS versions in parallel can lead to (smaller) issues. (QGIS 3.x and 4.x do NOT share their user data between the major versions 3 and 4, but all their subversions do share between themselves).
Cheers, Hannes
On 8/14/26 12:05, Blöcher, Ralf via QGIS-User wrote:
> If I have version 3.34 installed and manually install version 3.44 over it, a second instance is also created. So this has nothing to do with the software distribution solution.
> Is there a way to download the latest QGIS LTR version and then install it over an existing version?
> i.A. Ralf Blöcher
> Informationstechnologie
> E-Mail r.bloecher at traffiq.de
> traffiQ
> Lokale Nahverkehrsgesellschaft Frankfurt am Main mbH Stiftstr. 9 - 17
> 60313 Frankfurt am Main
> Geschäftsführer: Prof. Dr.-Ing. Tom Reinhold
> Aufsichtsratsvorsitzender: Stadtrat Wolfgang Siefert Amtsgericht
> Frankfurt am Main - HRB 42452
> USt-ID: DE187077253
> www.traffiQ.de
> Von: QGIS-User <qgis-user-bounces at lists.osgeo.org> Im Auftrag von Greg
> Troxel via QGIS-User
> Gesendet: Freitag, 14. August 2026 11:26
> An: Blöcher, Ralf via QGIS-User <qgis-user at lists.osgeo.org>
> "Blöcher, Ralf via QGIS-User" <qgis-user at lists.osgeo.org> writes:
>> I have a question about QGIS Desktop and updating to a new version.
>> We install QGIS Desktop using a software distribution tool called PDQ Deploy. We use this to install the QGIS-OSGeo4W-3.34.11-1_LTR.msi file remotely on Windows clients.
>> If I simply install the new Version QGIS-OSGeo4W-3.44.12-1_LTR.msi file 'over' version 3.34, a second instance of QGIS is installed on the computer.
>> But how can I remotely update version 3.34.11-1_LTR to version QGIS-OSGeo4W-3.44.12-1_LTR.msi using a software deployment tool without installing a second instance?
> This question is about "PDQ Deploy", which appears to be a paid-for, proprietary tool. I suggest you address questions about PDQ Deploy not doing what you want to your PDQ support contacts.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
More information about the QGIS-User
