[Qgis-user] Can't find the CRS mentioned in section 14.2.2 of the Training Manual
Jose Gomez
joselogomdi at gmail.com
Thu Oct 22 20:59:30 PDT 2026
hí Andrea,
You just need to enter the EPSG code in the filter field, as shown in
David’s image, then select it from the list that appears below, and that’s
it.
Regards.
José Luis.
El jue, 22 oct 2026 a la(s) 5:42 p.m., Andrea Giudiceandrea via QGIS-User (
qgis-user at lists.osgeo.org) escribió:
> Hi Jeff,
> which QGIS version exactly are you using? On which Operative System?
> What do you mean exactly with "picklist"?
> Please explain in a very detailed way how are you searching for the
> EPSG:3067 and EPSG:2392 CRSs in QGIS.
> Tip: just use the strings EPSG:3067 and EPSG:2392 (without any leading
> and trailing spaces) to search for such CRSs in the Project ► Properties
> ► CRS filter.
> Regards.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
Saludos,
José Luis.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20261022/d4d8481a/attachment.htm>
More information about the QGIS-User
