[QGIS-ZA-user] CRS Trouble - EPSG:4326 -->EPSG:2048
Neil Falconer
nfalconersa at gmail.com
Tue Mar 26 22:49:14 PDT 2019
Hi Erick,
The CRS of the data is currently EPSG:4326 ie WGS84 Decimal Degrees.
If you Use the Export --> Save Feature As... option and from the CRS
options select ZANGI HBKNO19, it ought to solve the problem.
EPSG 2048 is the conventional South Oriented projection system. There has
been some recent discussion on the forum on this.topic and one needs to
first analyse the projection information for any data one receives (it
should be standard practice to do this in any case to confirm that the CRS
of any data does indeed appear to be what has been defined.
Trust this helps
Regards
Neil Falconer
On Wed, Mar 27, 2019 at 1:10 AM E. Ndava via qgis-za-user <
qgis-za-user at lists.osgeo.org> wrote:
> Hi List
> This is not really a QGIS specific question/ issue, just that I am trying
> to achieve something within QGIS.
> The Case:
> I have data (geopackage attached) with crs WGS84, EPSG:2643 which I have
> gone through hoops and loops to no avail, to re-project to EPSG:2048. The
> result I am getting is to the effect that the data is flipped over the
> equator.
> An workarounds/ methodology / pointers to something I am missing?
> PS: I have worked through shapefiles, geopackage and PostGIS...same result.
> Thanks
> Erick.
> | @erickndava | http://erickndava.github.io/ |
> Thou art my hiding place; thou shalt preserve me from trouble; thou shalt
> compass me about with songs of deliverance. Selah. Psalm 32:7
> qgis-za-user mailing list
> https://lists.osgeo.org/mailman/listinfo/qgis-za-user
URL: <http://lists.osgeo.org/pipermail/qgis-za-user/attachments/20190327/6f0eba24/attachment.html>
More information about the qgis-za-user
