[STDM-user] Problems with STDM out of the box
Olivier Dalang
olivier.dalang at gmail.com
Thu Dec 18 08:17:44 PST 2014
Dear list,
I've trouble using the STDM plugin with default setup.
I run QGIS 2.6.1 and Postgres 9.3. I installed STDM by :
- checking out the stdm-plugin repo (master) in my plugin's directory
- running template_stdm_database.sql in a fresh postgres database (from the
stdm-database repo)
I encountered a small SQL error :
> ERROR: rule "geometry_columns_delete" for relation "geometry_columns"
> already exist
Which I solved by adding "OR REPLACE" on the rules creations.
Then, when opening QGIS and logging in the SDTM plugin (using the postgres
admin account), I get this message :
> Mapper Mapper|Party|party could not assemble any primary key columns for
> mapped table 'party'
I don't know if it's serious, but then, when I try to add content through
the [+] button in Modules>Household, I get an empty form with only "ok" or
"cancel".
Note that I tried to install using the normal install, but had a message
"Installation has failed". The error log was empty...
Anyways, I'd rather use my already existing QGIS/PostGIS installations.
Any idea on what's happening ? Is template_stdm_database.sql (from the
stdm-database repo) up to date ?
Thanks a lot,
Olivier Dalang
URL: <http://lists.osgeo.org/pipermail/stdm-user/attachments/20141218/ae10c526/attachment.html>
More information about the STDM-user
