[Fwd: Re: [webmap-discuss] zoomlevels in OWSContext?]
Steven M. Ottens steven.ottens at geodan.nl
Tue Jul 4 04:54:30 EDT 2006
Hi all,
As Tom said, we've to decide for ourselves what the extension should
look like. From what I understood is the following extension correct, so
I propose we use it:
<wms-c:ZoomLevels>128,64,32,16,8,4,2,1</wms-c:ZoomLevels>
where xmlns:wms-c="http://wiki.osgeo.org/index.php/WMS_Tile_Caching"
Note that the zoomLevels go from big to small numbers. Also <ZoomLevels>
is a child of <Layer>
regards,
Steven
Kralidis,Tom [Burlington] wrote:
> (Thanks Daniel for forwarding this to me, I'm now a part of this list
> again :))
>> Steven M. Ottens wrote:
>>> Currently we store out layers in a WMC document, but we're
>> switching
>>> to OWSContext to allow for more types of layers then just
>> WMS layers.
>>> Since the zoom levels are depending on the server, it makes
>> sense to
>>> me to store these levels in OWSContext. Are there any OWSContext
>>> experts around who can tell me if that's already in the standard,
>> No, that's not part of the OWSContext schema. I participated
>> in the OWS Context IE and don't remember the question of
>> storing multiple zoom levels even being raised at all. Note
>> that WMS doesn't support the concept of fixed zoom levels
>> either, so before multiple zoom levels can be added to OWS
>> Context some work will be required upstream in WMS.
> Correct.  Since OWSContext is based on OGC specifications, this doesn't
> apply.
>>> if not, what would be a proper place and name
>>> for such a thing?
>> If I remember correctly an extension mechanism was included
>> in the schema that could possibly be used for that. I think
>> Tom Kralidis would be the best one to answer on this. I CC'd
>> him in case he is not on this list.
> There is an extension element in the OWSContext schemas (schema chunk
> below) which allows this:
> 	<xs:complexType name="ExtensionType">
> 		<xs:annotation>
> 			<xs:documentation>This allows additional
> elements to be added to support non WMS Layer
> services.</xs:documentation>
> 		</xs:annotation>
> 		<xs:sequence>
> 			<xs:any namespace="##any"
> processContents="lax"/>
> 		</xs:sequence>
> 	</xs:complexType>
> Yes, fairy dust :)
> The basic approach is to define your own namespace in the root element
> of the OWSContext instance doc (i.e. xmlns:foo="http://foo/foo"), and
> then use that prefix within the document when applying your own
> constructs, i.e.:
> <foo:zoomLevels>1,2,4,8,16,32,64</foo:zoomLevels>
> Having said this, if you are going to be adding extensions, I would
> suggest that these be agreed upon in some way, so at the least the
> extensions are defacto; so it's great that it's being discussed here.
> ..Tom
>> Daniel
>> Daniel Morissette
>> http://www.mapgears.com/
> To unsubscribe, e-mail: webmap-discuss-unsubscribe at mail.osgeo.org
> For additional commands, e-mail: webmap-discuss-help at mail.osgeo.org
Geodan S&R Amsterdam
Geodan S&R
President Kennedylaan 1
1079 MB Amsterdam (NL)
Tel: +31 (0)20 - 5711 311
Fax: +31 (0)20 - 5711 333
E-mail: steven.ottens at geodan.nl
Website: www.geodan.nl
Disclaimer: www.geodan.nl/disclaimer
More information about the Webmap-discuss mailing list
