[Wps-discuss] Proposal to skip 2015 WPS benchmark
Jody Garnett jgarnett at boundlessgeo.com
Wed Apr 22 09:13:58 PDT 2015
understood.
On Wed, Apr 22, 2015 at 2:47 AM, Benjamin Proß <b.pross at 52north.org> wrote:
> Dear WPS developers,
> As you may know, I am responsible for the next WPS benchmark. The results
> usually are presented at the international FOSS4G conference.
> This time it takes place in Seoul. I will not be able to travel there and
> so I cannot perform my sheriff duties. The FOSS4G 2016 will take place in
> Bonn, which is right around the corner from where I work.
> This is one reason why I would propose to skip the 2015 WPS benchmark. The
> other reason is that we will have more time to set up the benchmark/test
> plan.
> I think there is already a good basis that hopefully will be extended with
> OGC compliance tests, maybe also for WPS 2.0.
> We are also planning to write a peer-reviewed paper about WPS
> interoperability which could hopefully be connected to the benchmark in
> some way.
> Writing the tests and paper will take some time and so I hope you can
> understand why I propose to skip this year.
> Let me know, if you have any comments or questions. I also will give you
> status updates via this list.
> Cheers,
> Benjamin
> Benjamin Proß
> Software Engineer
> 52°North Geoprocessing Community
> 52°North Initiative for Geospatial Open Source Software GmbH
> Martin-Luther-King-Weg 24
> Fon: +49-(0)-251–396371-42
> Fax: +49-(0)-251–396371-11
> http://52north.org/
> General Managers: Dr. Albert Remke, Dr. Andreas Wytzisk
> Local Court Muenster HRB 10849
> Wps-discuss mailing list
> Wps-discuss at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/wps-discuss
Jody Garnett
Technical Lead | Boundless <http://boundlessgeo.com/>
jgarnett at boundlessgeo.com <http://mailto:jgarnett@boundlessgeo.com/>
877-673-6436
@jodygarnett <https://twitter.com/jodygarnett>
[image: http://boundlessgeo.com/] <http://boundlessgeo.com/>
URL: <http://lists.osgeo.org/pipermail/wps-discuss/attachments/20150422/3765b896/attachment.html>
More information about the Wps-discuss mailing list
