[Wps-discuss] Proposal to skip 2015 WPS benchmark
Jachym Cepicky
jachym.cepicky at gmail.com
Thu Apr 23 03:17:04 PDT 2015
+1
st 22. 4. 2015 v 18:14 odesílatel Jody Garnett <jgarnett at boundlessgeo.com>
napsal:
> understood.
> On Wed, Apr 22, 2015 at 2:47 AM, Benjamin Proß <b.pross at 52north.org>
> wrote:
>> Dear WPS developers,
>> As you may know, I am responsible for the next WPS benchmark. The results
>> usually are presented at the international FOSS4G conference.
>> This time it takes place in Seoul. I will not be able to travel there and
>> so I cannot perform my sheriff duties. The FOSS4G 2016 will take place in
>> Bonn, which is right around the corner from where I work.
>> This is one reason why I would propose to skip the 2015 WPS benchmark.
>> The other reason is that we will have more time to set up the
>> benchmark/test plan.
>> I think there is already a good basis that hopefully will be extended
>> with OGC compliance tests, maybe also for WPS 2.0.
>> We are also planning to write a peer-reviewed paper about WPS
>> interoperability which could hopefully be connected to the benchmark in
>> some way.
>> Writing the tests and paper will take some time and so I hope you can
>> understand why I propose to skip this year.
>> Let me know, if you have any comments or questions. I also will give you
>> status updates via this list.
>> Cheers,
>> Benjamin
>> Benjamin Proß
>> Software Engineer
>> 52°North Geoprocessing Community
>> 52°North Initiative for Geospatial Open Source Software GmbH
>> Martin-Luther-King-Weg 24
>> Fon: +49-(0)-251-396371-42
>> Fax: +49-(0)-251-396371-11
>> http://52north.org/
>> General Managers: Dr. Albert Remke, Dr. Andreas Wytzisk
>> Local Court Muenster HRB 10849
>> Wps-discuss mailing list
>> Wps-discuss at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/wps-discuss
> Jody Garnett
> Technical Lead | Boundless <http://boundlessgeo.com/>
> jgarnett at boundlessgeo.com <http://mailto:jgarnett@boundlessgeo.com/>
> 877-673-6436
> @jodygarnett <https://twitter.com/jodygarnett>
> [image: http://boundlessgeo.com/] <http://boundlessgeo.com/>
URL: <http://lists.osgeo.org/pipermail/wps-discuss/attachments/20150423/64cf0dee/attachment.html>
More information about the Wps-discuss
