[ZOO-Discuss] Using zoo project to process a raster file
Gérald Fenoy gerald.fenoy at geolabs.fr
Wed May 25 06:01:47 PDT 2011
Thomas,
thanks to your feedbacks, it should now be fixed in the SVN rev. 214 [1] and should return an
ExceptionReport document containing the following message :
Unable to find a valid protocol to download the remote file /home/user/test_gml.gml
It is now more clear that the ZOO-Kernel is waiting for a remote file rather than a local one.
Hope it helps,
best regards,
[1] http://zoo-project.org/trac/changeset/214
Le 24 mai 2011 à 23:54, Thomas Tilak a écrit :
> Hello,
> I am trying to use zoo project framework to process a raster file (actually, for now just to extract a ROI).
> I have performed zoo project workshop and I have studied the Boundary C function hoping to use it to write my extract function.
> I have a problem with the inputs. I am using th console version with the following commands:
> ./zoo_loader.cgi "request=Execute&service=WPS&version=1.0.0&Identifier=Boundary&DataInputs=InputPolygon=Reference at xlink:href=http%3A%2F%2Fwww.zoo-project.org%3A8082%2Fgeoserver%2Fows%3FSERVICE%3DWFS%26REQUEST%3DGetFeature%26VERSION%3D1.0.0%26typename%3Dtopp%3Astates%26SRS%3DEPSG%3A4326%26FeatureID%3Dstates.28&RawDataOutput=Result at mimeType=application/json"
> ./zoo_loader.cgi "request=Execute&service=WPS&version=1.0.0&Identifier=Boundary&DataInputs=InputPolygon=Reference at xlink:href=%2Fhome%2Fuser%2Ftest_gml.gml&RawDataOutput=Result at mimeType=application/json"
> The first command works perfectly but in the second one, it crashes and gives the message:  "ZOO Kernel failed to process your request receiving signal 11 = SIGSEGV"
> I have attached the gml file used to my message.
> I would like to know how exactly should be the inputs set to fit zoo project expectations. Do you have an example of service working with raster file?
> Thank you.
> Thomas.
> <test_gml.gml>_______________________________________________
> Zoo-discuss mailing list
> Zoo-discuss at gisws.media.osaka-cu.ac.jp
> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
Gérald Fenoy
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20110525/0a18771f/attachment.html>
More information about the Zoo-discuss mailing list
