[ZOO-Discuss] Using zoo project to process a raster file
nicolas bozon nicolas.bozon at gmail.com
Thu May 26 07:05:57 PDT 2011
Hello Thomas,
Regarding raster processing services, we have gdal grid , translate and
profile code available here:
http://www.zoo-project.org/trac/browser/trunk/zoo-services/gdal
They are all working with fileName as InputData, but not with raw geotiff.
However, installing GRASS 7.0 and WPSBridge along with your ZOO Kernel
installation will let you work with geotiff directly as input, and run most
of the GRASS raster modules.
Hope you can give us feedbacks on your ZOO-Project use.
Best,
Nick
2011/5/25 Gérald Fenoy <gerald.fenoy at geolabs.fr>
> Thomas,
> thanks to your feedbacks, it should now be fixed in the SVN rev. 214 [1]
> and should return an
> ExceptionReport document containing the following message :
> Unable to find a valid protocol to download the remote file
> /home/user/test_gml.gml
> It is now more clear that the ZOO-Kernel is waiting for a remote file
> rather than a local one.
> Hope it helps,
> best regards,
> [1] http://zoo-project.org/trac/changeset/214
> Le 24 mai 2011 à 23:54, Thomas Tilak a écrit :
> Hello,
> I am trying to use zoo project framework to process a raster file
> (actually, for now just to extract a ROI).
> I have performed zoo project workshop and I have studied the Boundary C
> function hoping to use it to write my extract function.
> I have a problem with the inputs. I am using th console version with the
> following commands:
> ./zoo_loader.cgi
> "request=Execute&service=WPS&version=1.0.0&Identifier=Boundary&DataInputs=InputPolygon=Reference at xlink
> :href=http%3A%2F%2Fwww.zoo-project.org
> %3A8082%2Fgeoserver%2Fows%3FSERVICE%3DWFS%26REQUEST%3DGetFeature%26VERSION%3D1.0.0%26typename%3Dtopp%3Astates%26SRS%3DEPSG%3A4326%26FeatureID%3Dstates.28&RawDataOutput=Result at mimeType
> =application/json"
> ./zoo_loader.cgi
> :href=%2Fhome%2Fuser%2Ftest_gml.gml&RawDataOutput=Result at mimeType
> =application/json"
> The first command works perfectly but in the second one, it crashes and
> gives the message:  "ZOO Kernel failed to process your request receiving
> signal 11 = SIGSEGV"
> I have attached the gml file used to my message.
> I would like to know how exactly should be the inputs set to fit zoo
> project expectations. Do you have an example of service working with raster
> file?
> Thank you.
> Thomas.
> <test_gml.gml>_______________________________________________
> Zoo-discuss mailing list
> Zoo-discuss at gisws.media.osaka-cu.ac.jp
> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
>  Gérald Fenoy
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20110526/69c429c4/attachment.html>
More information about the Zoo-discuss mailing list
