[ZOO-Discuss] Zoo-discuss Digest, Vol 26, Issue 17
Gérald Fenoy gerald.fenoy at geolabs.fr
Thu May 26 13:11:44 PDT 2011
Dear Bomp,
Really nice to hear from you.
I noticed that the URL you provided in your email contains a xlink:href value wich is not URLEncoded as requested. You should always give to xlink:href an URLEncoded value else the ZOO-Kernel won't be able to download the requested remote file. In your case the inner request (the xlink:href value) even contains a request value.
If the second URL is not working it is probalu because there is not GeoServer instace running on your platform. If you are using the OSGeoLiveDVD then you should find a button to start it. After starting the GeoServer instace everything should be right.
Hope it helps.
Best regards.
Gérald Fenoy
Le 26 mai 2011 à 07:04, sittichai choosumrong <sittichai.ocu at gmail.com> a écrit :
> Hello,
> I am following the Zoo workshop version "FOSS4G 2010 workshop"
> I have a problem with the service using request. ( In the section 3.3.1.3.1)
> >>>  http://localhost/zoo/?request=Execute&service=WPS&version=1.0.0&Identifier=Boundary&DataInputs=InputPolygon=Reference@xlink:href=http://localhost:8082/geoserver/ows/?SERVICE=WFS&REQUEST=GetFeature&VERSION=1.0.0&typename=topp:states&
>         SRS=EPSG:4326&FeatureID=states.15
> but it show this text "Unenderstood<request>value.Please check that it was set to GetCapbilities, DescribeProcess of Execute"
> Then, I try to use only this URL to check the geoserver service on my system.
> >>>http://localhost:8082/geoserver/ows/?SERVICE=WFS&REQUEST=GetFeature&VERSION=1.0.0&typename=topp:states&SRS=EPSG:4326&FeatureID=states.15
> but it also not work.
> Could someone tell me how to solve this problem.
> Thank you
> Bomp
> Free and Open Source Software for Geospatial
> GIS Laboratory
> Osaka City University 大阪市立大学
> Sittichai Choosumrong
> TEL +81-90-6558-8559
> Zoo-discuss mailing list
> Zoo-discuss at gisws.media.osaka-cu.ac.jp
> http://gisws.media.osaka-cu.ac.jp/mailman/listinfo/zoo-discuss
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20110526/7d0b6035/attachment.html>
More information about the Zoo-discuss mailing list
