[Zoo-discuss] image as output value
Luca Delucchi lucadeluge at gmail.com
Tue Mar 19 07:04:25 PDT 2013
2013/3/19 Fenoy Gerald <gerald.fenoy at geolabs.fr>:
> Hey Luca,
Hi Gerald
> despite what I told you yesterday, it should now without size attribute in the map. Note that is a special case for Python and you should set the size when you are using other such as C, you can find in the qrencode source code example on how to set size [1].
If I remove size the it works
> Hope it helps,
thanks
> Best regards,
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
More information about the Zoo-discuss mailing list
