[Zoo-discuss] Introduction - Rémi Cresson
nicolas bozon nicolas.bozon at gmail.com
Wed Aug 5 22:36:03 PDT 2015
Hello Rémy,
Welcome to this list and thank you for such feedback and contribution.
It is very interesting to learn how Irstea is using and extending
ZOO-Project for the needs of the Geosud SDI.
As Gerald mentioned, please feel to share your services source code through
the ZOO-Project trac directly.
You are of course most welcome as new committer! Please accept the
committers guidelines on this list first so we can proceed.
IMHO, you would also be a great and valuable addition to the ZOO-Project
PSC. This will first take a request from the PSC Chair and then vote by
other PSC members.
Best regards,
Nick
2015-08-05 15:02 GMT+02:00 Fenoy Gerald <gerald.fenoy at geolabs.fr>:
> Welcome aboard Rémi !
> I am glad to hear that you are using the ZOO-Project and its OTB support
> even if it was not your original goal as you need to run the service
> remotely from the WPS server rather than running them directly on the same
> server.
> The work and the implementation you made looks very interesting and is a
> real asset to the ZOO-Project giving it the capability to be linked to a
> HPC infrastructure. So we welcome your contribution.
> Anybody can contribute code to the ZOO_Project, obviously if you need
> write access to the SVN then it will require that you are part of the
> ZOO-Project developers [1]. You should be member of the ZOO-Project PSC
> only in case you want to deal with the project organisation, plan and so on.
> Prior to ask the PSC for a vote, we should make sure that you agree with
> the committer guideline [2], once confirmed, I can then forward the request
> to the PSC.
> Hope to hear back from you,
> Best regards,
> [1]
> http://zoo-project.org/docs/contribute/code.html#for-registered-developers
> [2] zoo-project.org/docs/contribute/dev.html
> > Le 4 août 2015 à 15:21, Rémi Cresson <remi.cresson at teledetection.fr> a
> écrit :
> > Hello,
> > My name is Rémi Cresson, I work in the field of remote sensing image
> processing. I am currently with french National Research Institute of
> Science and Technology for Environment and Agriculture (Irstea) to develop
> a geospatial data infrastructure for the GEOSUD project. I work mainly with
> c++ libraries (GDAL, OTB, ITK, GEOS, ...) for image processing pipelines
> development. A goal of the project is to use supercomputers for remote
> sensing data processing, binded with web services.
> > We tried Zoo because it was the only open source WPS server which has a
> friendly binding with OTB applications. We used it, and found that Gerald
> did a nice work (at least a very solid proof of concept). However, we
> needed to launch our programs from a HPC architecture (i.e. not programs
> hosted by the WPS server as Zoo kernel do with OTB applications libraries).
> Indeed, we wanted to make use of our supercomputer's front node job
> scheduler in order to delegate resources management, job submitting, ...
> That leads us to implement a new Zoo service, which use ssh/sftp on the WPS
> server side and DRMAA on the HPC front node side. This new Zoo service
> basically transfert files between WPS server and HPC front node, construct
> a command line and submit a job, then transfert back files. We make it
> working with OTB applications only, using the same .zcfg files (but with
> another service name). We think the approach can be generalized to other
> existing processing libraries (Grass, ...). In addition, it can for sure be
> extended to parallel applications (MPI), as DRMAA can be used to dispatch
> process on a given number of nodes.
> > I want to contribute to zoo-project with this service, and I might be
> interested to be PSC member of Zoo-project in a near future, if however
> this is an option.
> > Thank you for taking time to read this, I look forward to responses !
> > Cheers,
> > Rémi Cresson - Research Engineer, Irstea
> > Maison de la Télédétection
> > 500 Rue de jean François Breton
> > 34090 Montpellier
> > Zoo-discuss mailing list
> > Zoo-discuss at lists.osgeo.org
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
> Gérald Fenoy
> http://wiki.osgeo.org/wiki/User:Djay
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20150806/3f8d90a8/attachment.html>
More information about the Zoo-discuss mailing list
