[Zoo-discuss] Compiling Zoo-kernel: fastcgi headers location
Fenoy Gerald gerald.fenoy at geolabs.fr
Fri Aug 28 03:13:39 PDT 2015
Rémi,
the revision 740 should solve the issue of a fastcgi library setup in a specific location.
I kept the —with-fastcgi option which was already available in the configure.ac file but was not used.
Now, the value set to this option flag should be correctly used.
Best regards,
> Le 28 août 2015 à 10:51, Rémi Cresson <remi.cresson at teledetection.fr> a écrit :
> Hi Gerald,
> Thank you for your reply. Installing libfcgi-dev from ubuntu packages solves the issue. This places the stuff in /usr/local or something similar, and zoo-kernel compiles fine.
> (However, if one needs to build zoo-kernel with fcgi in a non standard location:
> -run configure script
> -modify makefile (remove every "-lfcgi")
> -modify ZOOMakefile.opt, add "-I/path-to-fcgi/include" in MSFLAGS and "-L/path-to-fcgi/lib" before "-fcgi" in OTBLDFLAGS
> -run make
> I think it might be nice to add a --fcgi-include-dir and a --fcgi-library in the Zoo-kernel configure script, in order to ease the compilation of Zoo-kernel with fcgi in a non-standard location.)
> On 27/08/2015 19:18, Fenoy Gerald wrote:
>> Hello Rémi,
>> sorry for late reply.
>> On Ubuntu 12.04 you should follow instructions from here [1]. Amongst all instructions, the important one in your case is that you should install the libfcgi-dev package to have the requested header files.
>> I suppose this solve your issue.
>> Best regards,
>> [1] http://zoo-project.org/docs/install/debian.html
>>> Le 24 août 2015 à 12:21, Rémi Cresson <remi.cresson at teledetection.fr> a écrit :
>>> Hello,
>>> Trying to compile the zoo-kernel, I always have encountered this issue (fatal error: fcgi_stdio.h: No such file or directory) on a Linux Ubuntu 12.04 system.
>>> What I usually do is a dirty hack, by creating hardlinks, or copying the missing headers. But is there any proper way to tell the compiler where fastfcgi headers are?
>>> I did not find any other workaround, so I'm asking you.
>>> Cheers,
>>> Rémi
>>> Zoo-discuss mailing list
>>> Zoo-discuss at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/zoo-discuss
>> Gérald Fenoy
>> http://wiki.osgeo.org/wiki/User:Djay
Gérald Fenoy
More information about the Zoo-discuss mailing list
