[Zoo-discuss] Zoo - Mapserver Issues - Segmentation fault
Jonathan mayer
jonrmayer at yahoo.com
Mon Nov 16 22:51:12 PST 2015
Dear List,
I am at a complete loss of how to get mapserver (6.20 with mapmint patch applied) to return a wms response
Everything else works fine - I can get either a json or a gml response and mapserver is working propely on its own - I have tested it with a mapfile.
I keep on receiving the following error:-
Status: 501 Internal Server Error
Segmentation fault (core dumped)
All help gratefully received.
Regards,
Jonathan
Config File
[main]lang=en-USversion=1.0.0encoding=utf-8serverAddress=http://localhost/zoodataPath=/var/www/html/temptmpPath=/var/www/html/temptmpUrl=http://localhost/tempcacheDir=/var/www/html/tempmapserverAddress=http://localhost/cgi-bin/mapservmsOgcVersion=1.0.0
.zcfg file
[testgeo_ms]
Title = Compute boundary.
Abstract = Returns the boundary of the geometry on which the method is invoked.
processVersion = 1
storeSupported = true
statusSupported = true
serviceProvider = testgeo_ms
serviceType = Python
<MetaData>
title = Demo
</MetaData>
<DataInputs>
[InputPolygon]
Title = Polygon to compute boundary
Abstract = URI to a set of GML that describes the polygon.
minOccurs = 1
maxOccurs = 1
<MetaData>
Test = My test
</MetaData>
<ComplexData>
<Default>
mimeType = application/json encoding = UTF-8
</Default>
<Supported>
</Supported>
</ComplexData>
</DataInputs>
<DataOutputs>
[Result]
Title = The created geometry
Abstract = The geometry containing the boundary of the geometry on which the method was invoked.
<MetaData>
Title = Result
</MetaData>
<ComplexData>
<Default>
</Default>
<Supported>
mimeType = image/png
useMapserver = true
asReference = true
msStyle = STYLE COLOR 125 0 105 OUTLINECOLOR 0 0 0 WIDTH 3 END
</Supported>
<Supported>
mimeType = image/tif
useMapserver = true
asReference = true
</Supported>
<Supported>
mimeType = application/vnd.google-earth.kmz
useMapserver = true
asReference = true
</Supported>
</ComplexData>
</DataOutputs>
Python File
import zoodef testgeo_ms(conf,inputs,outputs): outputs["Result"]["value"]=inputs["InputPolygon"]["value"] return zoo.SERVICE_SUCCEEDED
Example Request through ./zoo_loader_ms.cgi < /var/www/html/temp/a.xml
<wps:Execute service="WPS" version="1.0.0" xmlns:wps="http://www.opengis.net/wps/1.0.0" xmlns:ows="http://www.opengis.net/ows/1.1" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/wps/1.0.0 ../wpsExecute_request.xsda"> <ows:Identifier>test_ms.testgeo_ms</ows:Identifier> <wps:DataInputs> <wps:Input> <ows:Identifier>InputPolygon</ows:Identifier> <wps:Data> <wps:ComplexData mimeType="application/json">{ "type": "MultiPolygon", "coordinates": [ [ [ [ -105.998360, 31.393818 ], [ -106.212753, 31.478128 ], [ -106.383041, 31.733763 ], [ -106.538971, 31.786198 ], [ -106.614441, 31.817728 ], [ -105.769730, 31.170780 ], [ -105.998360, 31.393818 ] ] ], [ [ [ -94.913429, 29.257572 ], [ -94.767380, 29.342451 ], [ -94.748405, 29.319490 ], [ -95.105415, 29.096958 ], [ -94.913429, 29.257572 ] ] ] ] } </wps:ComplexData> </wps:Data> </wps:Input> </wps:DataInputs> <wps:ResponseForm> <wps:ResponseDocument> <wps:Output mimeType="image/png" asReference="true"> <ows:Identifier>Result</ows:Identifier></wps:Output> </wps:ResponseDocument> </wps:ResponseForm></wps:Execute>
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20151117/558d418f/attachment.html>
More information about the Zoo-discuss
