[Zoo-discuss] Fwd: Installation of Zoo in Windows 10
Anju Bajpai bajpai.anju at gmail.com
Thu Jun 23 03:37:45 PDT 2016
Dear Fenoy,
Thank you so much. My zoo kernel has started working.
Thanks a lot.
Anju Bajpai
On Thu, Jun 23, 2016 at 3:24 PM, Fenoy Gerald <gerald.fenoy at geolabs.fr>
wrote:
> Dear Anju,
> you should take a look at the CGI-Exe1 handler from your IIS configuration
> interface and make sure it accept all the HTTP verb, which should be the
> case when the installer has run the following command:
> appcmd set config /section:handlers
> /+[name='CGI-exe1',path='*.cgi',verb='*',modules='CgiModule']
> You should not define any mimeType for cgi application. Indeed, it will be
> the ZOO-Kernel responsibility to generate the adequate mimeType depending
> on the request sent by clients.
> Personally I would also try to access the ZOO-Kernel using the following
> very basic request: http://localhost/cgi-bin/zoo_loader.cgi . If it
> returns an exception report then it means that only the POST request cause
> the trouble and we should find the way to solve it after we are sure that
> at least GET is working.
> I hope this helps and it can solve your issue.
> Bets regards,
> > Le 23 juin 2016 à 11:18, Anju Bajpai <bajpai.anju at gmail.com> a écrit :
> > Dear Fenoy,
> > Thankyou for giving a quick reply.I have run the command given by you
> but it is giving message as "ERROR ( message:New add object missing
> required attributes. Cannot add duplicate collection entry of type 'add'
> with unique key attribute 'path' set to
> 'c:\inetpub\cgi-bin\zoo_loader.cgi'. By the way what is the mime type for
> CGI in IIS 10 Windows 10? I have added it as Filename Extension = ".cgi"
> MIME Type:-"magnus-internal/cgi"
> > See Screenshot for the error loading zoo_loader.cgi
> > <image.png>
> > Please help regarding this.
> > On Thu, Jun 23, 2016 at 2:06 PM, Fenoy Gerald <gerald.fenoy at geolabs.fr>
> wrote:
> > Dear Anju,
> > thanks for trying to use the ZOO-Project on your windows platform.
> > The error you have means that something went wrong during the
> configuration of your IIS from the installer.
> > I would like to invite you to try the following commands: [1]. It
> contains all the command which should be run from the installer, you may
> have noticed that the last line of the commands has been added few weeks
> ago so it may explain why this was missing in the installer at that time.
> So first I would try this command from a cmd run as administrator:
> > appcmd.exe set config /section:isapiCgiRestriction
> /+[path='c:\inetpub\cgi-bin\zoo_loader.cgi',description='ZOO-Project',allowed='True']
> > I hope this helps and you can confirm that it solved you issue.
> > Best regards,
> > [1] http://www.zoo-project.org/docs/install/windows.html#install-by-hand
> > > Le 23 juin 2016 à 08:53, Anju Bajpai <bajpai.anju at gmail.com> a écrit :
> > > Dear All,
> > > I have just started exploring zoo and it's WPS features for GIS
> projects.But after installation in IIS 10 and Python  2.7 using Zoo
> Installer for Windows(32 bit Windows10), I am getting the following error:-
> > > POST http://localhost/cgi-bin/zoo_loader.cgi   405 Method Not Allowed
> > > Can you please tell me what could be the possible reason for this?
> > > Anju Bajpai
> > > RRSC-C
> > > Nagpur
> > > _______________________________________________
> > > Zoo-discuss mailing list
> > > Zoo-discuss at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/zoo-discuss
> > Gérald Fenoy
> > http://wiki.osgeo.org/wiki/User:Djay
> Gérald Fenoy
URL: <http://lists.osgeo.org/pipermail/zoo-discuss/attachments/20160623/ab505b3a/attachment-0001.html>
More information about the Zoo-discuss mailing list
