[ZOO-PSC] [mapserver-users] Tinyows as a WFS-T server - error commiting write
Jeff McKenna jmckenna at gatewaygeomatics.com
Mon Apr 4 09:32:11 PDT 2016
Hello Gérald,
Congratulations on your appveyor work.
It is interesting timing of course, as I am working very hard on the
MS4W build process, preparing the environment for the ZOO-Project.  I've
been fulltime on MS4W since September, when ms4w.com was launched.
Of course, in the perfect world your response would have been "great
timing, we really need ZOO-Project distributed on Windows, with
MapServer 7 support, and instead of spending so much time learning the
process ourselves, we have chosen to fund Gateway Geomatics to add this
into MS4W, for the entire MapServer and ZOO-Project community".  :)
Good luck with your appveyors builds.
As you know, or might not know, MS4W environment is much different than
the environment you chose.  All libraries are kept uptodate, and a
strict release cycle is followed (this makes sure all 160+ libraries are
kept uptodate, which, maybe you should check into about the libraries
you chose to use, you will find most are very old).  It is a lot of
work, as you are finding out (likely why you chose to use libraries
compiled elsewhere).  None of the 160+ libraries are compiled
externally, it is all done in-house.
Anyway, I just thought I'd update the ZOO-Project PSC with this effort.
  I hope to have something to the MapServer community soon.  As you
noticed in my recent public messages, the GeoMOOSE developer community
has been using MS4W for their WFS-T through TinyOWS (I did all that
unfunded by the way).  I am doing the same for ZOO-Project.
I expect you'll see public messages from me this month, on issues
related to these builds.  I can imagine I'll be hitting many issues,
with newer library versions, compilers, and all that fun, soon :))))
Thanks for listening,
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2016-04-04 4:29 AM, Fenoy Gerald wrote:
> Hello Jeff and Venka,
> I am very glad to hear that ZOO-Project may be packed into the MS4W distribution.
> I would like to thanks a lot Jeff for his continuous support to ZOO-Project for integrating with other softwares.
> It take long time for me to answer, cause since last week we were experimenting automatic building using appveyor.
> We initially tried to build everything from scratch and we got some results [1], nevertheless it was a too long build process to be able to test using it. There was no link between each built softwares. Nevertheless, you may notice that from here the link between each softwares is ensured [2].
> Anyway, we have made another account (in fact to be hornets we have 4 accounts right now there on appveyor to make parallel testings) which can be used to download the latest version available (note that once I will solve the issue for publishing the latest version on bintray.com we can directly use the download icon from there).
> So, this last account is named djay, my nickname, and is accessible from here [3]. I suppose that it may be of some help to integrate it in MS4W.
> Note that the current build system is using the MapServer available in the SDK from gisinternal, which I think correspond to the 6.4 dot something version. Note that on my current MapMint version I am successfully using MapServer 7.0.1 so it should not hurt to build against this newer version. Note that we may also integrate the MapServer 7.0.1 support directly inside the build process to provide binary distribution of both ZOO-Project and MapServer.
> I hope that this work can help the ZOO-Project to graduate to MS4W.
> Thanks again Jeff for your continuous support.
> Best regards,
> [1] https://ci.appveyor.com/project/gfenoy/trunk/build/1.1.175
> [2] https://ci.appveyor.com/project/gfenoy/trunk/build/1.1.237
> [3] https://ci.appveyor.com/project/djay/trunk
>> Le 29 mars 2016 à 17:00, Venkatesh Raghavan <raghavan at media.osaka-cu.ac.jp> a écrit :
>> Would be great to see ZOO packed into ms4w.
> Gérald Fenoy
> http://wiki.osgeo.org/wiki/User:Djay
More information about the Zoo-psc mailing list
